Oct 21, 2011 1:02 AM
Variax Crackling
Like (0)
I'm not guite sure how to describe this sound but lately my Variax gets a crackling noise when using the CAT-5 cable. It doesn't happen all the time. When it does happen it just keeps getting worse and worse if left alone. It is a steady crackling. I can still hear model when it happens but it eventually overwhelms the models sound. Switching to different models doesn't help. Sometimes switching the product (X3 Live or Vetta II) off and then back on gets rid of it but not always. More often it doesn't fix it. Shaking the cable doesn't effect it for the better or worse. Have tried different cables (I have three) and doesn't correct it. If the CAT-5 contacts are dirty i.e. doesn't contact properly, would that cause it? Or could it be I need to reseat my connectors? Would that cause this. Any thoughts? I haven't tried cleaning the contacts because I know how fragile they are from personal experience and don't want to risk damaging them. Has anyone else experienced this phenomenon?
I used to find that my Variax 300 would "crackle" during the dry winter months if static electricity built up on the scratch guard. It was not, however, constant. I used to keep an old Bounce sheet in my pocket to dissipate the charge on the pick plate, BTW.
If you use a quality, non-lubricated contact cleaner on the VDI connector and simply spray it on/in the parts, you may clear any lint or debris that may be a contributing factor. This should not cause any damage. While you're at it, why not clean ALL the connectors, pots and switches, and don't forget the bridge saddles, either.
[The Great, All-Knowing One will interject any steps I have missed when he descends from the mountaintop later this evening.]
Regards,
J/W
Another thing to try is compressed air in the guitar's receptacle. If all cleaning techniques fail, you may need to have a service center look at it. They can be found at http://line6.com/service_centers/.
Man, I've got the same problem as you and it drives me crazy.
I got my Variax 600 used and when I got it, I could only play it through the Line 6 XPS-AB box with the TRS cable and output it to the powered speaker (XLR cable) and to my amp (1/4" jack). I didn't have any of the POD's to plug it with the VDI cable.
I got so ****** off when the crackling came along that I thought I got problem either with cables, power supply, XPS AB box...all those were replaced with new but problem was still comming and going as it pleased to, convinsing me that issue is inside the Variax.
I describe the noise as similar to changing the stations on the old radio (by turning the wheel knob) and you just leave it in between the two stations.
I found out, if I take the guitar TRS cable, out and then plug it back into guitar, stops the problem for a few minutes/up to half an hour and also that action helps to show that there's something wrong with the guitar...cause people don't beleive when I tell them problem exist.
Sometimes I can plug in and play for a 5/15/30 minutes and problem wouldn't show up, so all I need to do is plug out/plug in the guitar cable few times ...and here it is, problem will eventually show up after few of those yanks.
I sprayed the contacts too, thinking that dust is causing problems and checked the basic connections /soldering on the guitar input jack but it didn't help.
Later on I bought HD500 (yesterday) just to see if the problem disappears when using the VDI cable (CAT-5)...but you guessed it, it's still there.
I read something on the forum about "similar" problem with the volume drop.
To highlight it, they needed to plug out/in the cable from the guitar jack.
Unfortunatelly it seems that their problem could permanently be fixed only by replacing COFFIN CASE ASSEMBLY, which can cost a lot of money.
I'm not sure if those two above problems are connected but there's definitelly similarity with the problem going away for a while when unplugging/plugging guitar cable.
I hope that I'm wrong and someone can clear it up how to get rid of the problem.
- This sounds exactly like a static buildup problem to me...
- You don't REPLACE the coffin assembly, you REMOVE it completely and fasten the circuit boars directly to the guitar body using nylon stand-offs: = CHEAP FIX
- I still say it could be one of three things: static, static, or static...
Good luck,
J/W
on the static thing...... i have no doubt about the possibility of static buildup. having been zapped at many a light switch over the years in winter. my question is this... shouldnt the grounding system of the guitar discharge any static that has built up when hooked up either through the 1/4 out or the vdi out?
if im right then these guitars that are collecting static electricity may have a ground fault?
i know in the 3 and 6 hundred there are wires on eother end of the coffin case that ground to the body. the question i have is this could that ground to the body be drawing in that static electric charge? if so there is a danger to the main chip.
inwhich case the removal of the coffin case is a valid thought.also using a non metalic standoff of some kind or and insulator between the boards and the body is also a valid thought.
when transplanting my 300 i removed all but the very tiny bit of the case that mounts the main board .. and it was epoxied to the back side of a danelectro pick guard. i can tell you thet a masonite body does not build up static.
anyhow ...i might look into all ground connections. your obviously not gonna get any help from the company with a schematic so youll have to look it over with what knowledge you may have.
O Great One, the scratch guard is not grounded to anything... it is just a piece of non-conductive plastic that picks up a surface charge that is diffused across the whole surface randomly. I'm not sure how you could set up a path to ground for static, since it is not flowing anywhere on its own.
J/W
yes i know what your saying and plastic normally being non conductive .... should not build up static electricity.. but for some reason it must be....so... if i wanted to ground the top of the pick guard and that must be where it is building up because the bottom of the pick guard is directly on top of the coffin case id be sure there was a good connection where the pots come through. there metal the coffin case is metal so there should be a static discharge when the guitar is connected. ergo. in my opinion there is a ground fault. for that matter again what do i know. you should be able to touch the pick guard and touch the 1/4 inch cable when its connected to the amp and not the guitar and discharge it that way. if not through proper ground connections. or for that matter just touch the 1/4 inch cable to the pick guard... should do the same thing.
also being a non conductive substance i might think that the pick guard must have picked up some coating of something that would conduct electricity. its quite possible that the bridge plate is holding the static . it is also supposed to be hooked into the ground system. either way if its the pick guard or the bridge plate. if there connected to the coffin case id say the static is working its way down to the case and causing a problem with the main chip. either way this static should discharge to ground if all is properly grounded. the bridge plate as i recall doesnt come in contact with the pick guard accept through the system of grounds. ...i could be wrong though but... i believe im on the right path as far as static discharge goes.
again it should ground through the controls there nuts and washers provide the contact. that is if all ground connections are correct
i might try cleaning the pick guard with some windex to remove any residual hand oil that may be on there for one thing . as i said above we all get shocked in the winter so obviously the oils in your skin.... conduct electricity ![]()
which kinda makes me wonder about some of these guitar polishes and just the motion of polishing possibly creating static electricity...
but well leave that for another time.![]()
The effects of static electricity are familiar to most people because people can feel, hear, and even see the spark as the excess charge is neutralized when brought close to a large electrical conductor (for example, a path to ground), or a region with an excess charge of the opposite polarity (positive or negative). The familiar phenomenon of a static 'shock' is caused by the neutralization of charge.
A ground wire does nothing for static electricity because - by definition - it is not flowing... the elctrons are just sitting there on the surface of a non-conductor going in no direction in particular. When you touch the surface with an opposite charge, you instantly neutralize the static and produce a spark. Otherwise, the electrons dissipate slowly on their own through ion-by-ion neutralization interactions with the air.
[The Wikipedia article on static electricity is pretty good...]
J/W
well i find it hard to believe to be honest with you that plastic itself will hold any kind of charge even static electricity. wikipedia is info that epople post its not the encylapedia britanica. and wikapedia has been known to be wrong.
anyhow thos suggestions i made still stand in my opinion and so well have to agree to dis agree on this one i guess. i have to say this is a new one to me static from plastic but hey who knows it all.
http://www.electrostatics.com/page2.html
i stand corrected to a point by this article. read the conductivity section for a possible soloution to this problem.
Great post by JW and amx05462 and interesting article to read!
Is there anywhere on the net (or can someone make a post here) pictures of modified guts inside the Variax, after the coffin assembly has been removed (and how is it done) and pcb board attached to the bare wood?
It would come very handy to all Variax owners to see how it's properly done.
I read somewhere that grounding problem inside the Variax was fixed by attaching aluminium sticky tape inside the guts( where the ground wires are normaly screwed into the body) and then reattaching those ground wires on to the aluminium tape. Apparently, that makes a better contact...right?
Anyone who knows about that? Any photos...links?
I guess that still wouldn't fix the problem with STATIC due to friction on the pickguard and that crackling hiss!?
Any ideas?
Cheers and thanks for the input guys!
If anyone knows where to link to such a picture, it will be the All-Knowing One.
His Eminence, however, has retired to his bed of nails, having had a long day of kissing babies, hearing the confessions of Variax owners who have voided their warranties by installing GraphTech pickups, and drinking (...ummmm. I mean) sprinkling Holy Water on orphans and widows...
Try him in the morning, and see what he can dig up...
Regards,
JellyWheat
oh i had all thos pics but the last computer glitch wiped all that stuff out. so im slowly collecting it again. in the mean time you may want to look around in here
http://line6.com/support/groups/variax-transplants
theres some references to that stuff and myold danelectro transplant you might even see some references to my project guitar in there. but some of the pics you seek could still be there as well.
as to mounting the controls have there respective holes. you can see that already. as to the standoffs well you can buy them at a local hardware store. or you can make some. when you remove the board you need to find a wood screw that will go throught the hole where the original screw went through not the same size though smaller in diameter but longer inlength youll need 4 of those.
then you get some plastic or rubber tubing and cut it to the height you want the board off the body. simple theres your stand off. cost probably 10 cents for the 4 of them also cut 4 thin washers to go between the head of the screws and the board. simple as pie. another way is you make a paper template of the board shape cut out the holes. transfer there places to the back of the pick guard. epoxy 4 machine screws in place. once hardened if you did them right they wont come off then put a rubber washer on the screw first then the board then another rubber washer then the nut. voila mounted to the pick guard as it was before.
these things are very easy to do.
What kind of sipping wine do you recommend when tackling a job like this, Excellency?
J/W
[...just wondering]
come on jw ....you know what i drink![]()
(8>*}... I was thinking about ...
..." Crackllin' Rosie "
Hnyuk, hnyuk, hnyuk!
J/W
arent cracklins fried pig skin?
I dunno, Excellency, but I used to call my first wife...
..."Cacklin' Rosie"
[Mebbe that's why she ditched me for the RotoRooter guy!]
J/W
[...is this gonna be another one of them "Removed Posts"?]
no you didnt say the word soit should be a safe post.
btw kinda on the same subject..... yer not textin from the porcelin throne again....i hope .. one of these days you could mess up that nice new phone....
Mrs. JellyWheat has come aboard me with the cannons blazing, telling me I should have greater respect for my good friends than to e-mail them from the terlet, new iPhone or not!
I HAVE been TOLE!
listen you know i dont mind where your emailing from but if your hands get slipery and your legs fall asleep while your texting .. you know . im just concerned that if the phone slips . or if your in the middle of a wipe or something that things could happen to your phone is all.
much like the no texting while driving law says.... well you know where im going with this...
(8>z}... You really ARE trying to get me booted off this Forum, aren't you, O Great, All-Knowing Stirrer of the Trapazoidal Pot!
Hrrrmph!
J/W
well if they boot you im going with you. wouldnt be the same if you werent here.
(8,>)}... REALLY, Great One?
J/W
yep the place would be a great big bore...
I've been xperiencing this problem... A LOT! and it is driving me and my bandmates CRAZY too! I had it on my Variax 600 with and without the VDI, and when I upgraded to a JTV-69 thought that all would be okay. Problem is... IT'S DOING IT AGAIN!
I've replaced the VDI cable, cleaned the contacts for the guitar, cable and POD X3. Purchased an new POD X3 and compressed air dusted the JTV-69 insides, and it still happens on the gig! I wish Line6 would come up with a definate cause and solution, because I'm about convinced that Line 6 only produces consumer products unfit for professional use!
