980 Views 5 Replies Latest reply: Nov 7, 2011 1:30 AM by Nick_Mattocks RSS
fanir Just Startin' 43 posts since
Oct 26, 2006
Oct 21, 2011 5:11 AM
Integrating POD HD500 and Amplitube 3?
Hi, I was wondering if it's possible to use the HD 500 to trigger the effects from Amplitube 3? If so, how do I go about doing it? I've searched around these forums that the only way to do that is through MIDI or USB which is a bit of a grey area for me. I'm currently using my Toneport as my recording interface.
  • DeanDinosaur Iknowathingortwo 443 posts since
    Jul 30, 2009
    Oct 21, 2011 5:16 AM (in response to fanir)
    Re: Integrating POD HD500 and Amplitube 3?
    Doesn't amplitube have some sort of midi learn? Meaning that each paramter in Amplitube has the ability to midi learn. Then all you have to do when you set the specific parameter that you want to controll to midi learn and then simply press the button or whatever it is in the midi device (in this case the pod hd) and Amplitube will learn it.  I'm sure you will get more help in the amplitube forum about this, I just remember reading about the midi learn in some advertisement long ago (it's supposed to be clicking on that parameter and choosing midi learn I believe) and hope that's the case and I'm almost sure they have it in their latest version
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Oct 21, 2011 5:40 AM (in response to fanir)
        For general recording purposes you don't need Toneport as your recording interface. You can connect the HD500 direct to your computer via USB and configure your DAW to use the HD500 and its ASIO driver as the audio input/output device.
        As for controlling Amplitube, I'm not sure how you do that but I don't think the Toneport will help. I know the HD500 will send MIDI commands but I'm not sure if they are sent over USB or whether you need to use the HD500 MIDI port. If the latter you will need a seperate MIDI interface to your computer/DAW - and Toneport isn't it.
      Mar 26, 2007
      Nov 7, 2011 1:30 AM (in response to fanir)
      Hi
      Yes - you can configure the Foot Switches FS-1 to FS8 and the expresssion pedal to send outgoing MIDI messages on any MIDI channel.  You'll need to know what message type and parameters to send from the receiving device's MIDI implementation chart.
      Hold down the MOVE button on the HD500 to enable outgoing MIDI message configuration.
      At this time it isn't possible to use MIDI to transfer settings entered by moving the amp modelling drive, tone and volume controls.
      Nick
