965 Views 2 Replies Latest reply: Nov 2, 2011 12:10 PM by ericjs RSS
ericjs Just Startin' 3 posts since
Dec 26, 2006
Oct 26, 2011 10:20 PM
Can I use my Pod X3 Live bass patches and bypass the modeling in the Lowdown HD400?
I tacked this matter to an already-answered question, but I think I need to make it a question on its own:
I recently bought a Lowdown HD400 bass amp head and a couple of speaker cabs.  I wanted to use my Pod X3 Live (for which I have created lots of bass patches) with my new rig, bypassing the HD400's models (in favor of the way more extensive amps/cabinets/fx in the X3).  I found a post with a similar topic, answered with a suggestion to use the FX Return on the Lowdown LD400 amp to bypass the modeling for use as a "clean power amp."  That was my first thought.  Problem is, my HD400 doesn't seem to have an effects loop, so no FX Return.  It shares the same manual Pilot's Guide) with the LD400, which doesn't appear to have an FX Return either!  So how can that answer be correct?  Please help-- what am I missing here?
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    That was not a correct answer that you read... the HD400's indeed do not have an FX Loop circuit in it's design.
    The only way to bypass amp modelling is to input via the mp3/CD jack on the back. This would route the input signal directly to the amp's output section and to any connected cabinets.
    I personally think you could get great results running the amp as clean as possible and just go in through the front end of the Low Down.
    Or, if you're really looking for some sonic depth... why not use both, but separately?
    Bass into X3 Live, DI to the PA/FOH. 1/4" output of the X3 Live feeds the Low Down HD400 set to as clean as possible a tone, sans FX. You could even mic one of the cabinets and have the sound engineer blend the two signals... just a thought.
    But yes, there is no FX Loop on the HD400.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
