1 ... 7 8 9 10 11 ... 13 Previous Next 58090 Views 190 Replies Latest reply: Apr 12, 2013 2:48 PM by Gorealex RSS Go to original post
  • mazuwa Iknowathingortwo 371 posts since
    Jul 7, 2006
    120. Mar 31, 2012 1:26 AM (in response to Karma180)
    Re: What every HD500 owner needs to know!
    Let us suppose you only have one real guitar getting into Guitar Input 1 and you only want to use this guitar:
    Now it depends on the preset:
    - if you have true stereo effects before a dual path like EQ, then use "SAME" to feed both channels.
    - if you have a mono effect before a single or dual path like a compressor, then use "VARIAX" because it produces less noise than "AUX", "SAME" would increase input volume at +3db because you doube the mono signal input. No matter what VARIAX channel (1or 2).
    - Choose also "SAME" if you have two channels (Path A + B) and want to change sound by panning or so.
  • anglepod Just Startin' 172 posts since
    Mar 24, 2012
    121. Apr 9, 2012 10:55 PM (in response to deanesque)
    Best way to deal with the issue is set the input 1 to Guitar and the 2nd to Aux, I split feed the inputs from a buffer pedal I have up front. Is the quietest setting which does not impede the sound on any split A-B channel thing. Using "same" makes for noise. I find various effects just add a terrible noise floor most rely on the gate to choke off the noise floor which also kills the normal dynamic of the true guitar tone. I only use one when I have to. I work to get the amp sounding as good as possible and usually I find using the PREamp model with the cabinet works the best and is more articulate w less bad clipping gain.
    I also find putting the impedance on "Auto" seems like it makes for less noise.
    The new 2.02 update allows you to set this "Global' for every preset on the above settings instead of having to change it everytime you create something.
    Check to the left of the previous Guitar/Same settings, it's a new feature.
    I gave up on trying to use the loop, just added noise even w nothing on. Dropped off my various pedals I had hoped to integrate just were not sounding that great through the loop no matter the technique I tried on levels and tricks.
    I run my POD into a rackmount BBE line level unit into an ART SL1-A power amp (100watt, stereo, 8 ohms) works great, my output config is on direct full power out. Hard to imagine someone said that did not drive their Crown Power amp. The level is very high. Master unit volume is at 3:00 almost too much drive.
    Sounds killer on my split 4x12 cab, very much like the real amps and feel. I like the BBE myself, some recording guys don't like it but it is probably from using it wrong. Mine never goes above 11:00 on the Lo contour and 12:00 on the Hi process. Less is more and correcting the phase lag just makes my amp models have more clarity punch and presence. Guitar Player rated the unit very high as a must have enhancement pedal. I agree, used correctly, it is NOT an effect pedal. I use my new line level rack unit on my HD500 as it is 2 channel. I wanted this unit for some cool amp experiements and it did not disapoint. I would prefer less effects and more useful ones as so many just do not function in a normal world for performance tones. Nothing can touch my Wampler Compressor.
    Sometimes I find I have to click the PAD level on the input to keep the levels from clipping,
    Having given up on the loop I run a Wampler Compressor>>Wampler Esctasy OD>>Fulltone DejaVibe>>>Radial PB-1 buffer/class A boost which I have a split jack on that feeding both the main and aux inputs. These are just remainers from my former massive pedal board which just sound better than anything in the unit.
    Although, I am finding uses for some of the DYN effects like the Tube Preamp and new Vintage Tube Mic Preamp. Just set clean to enhance. I find most of the delays and reverbs very good, some exceptional.
    MY major flaw lacking on the unit is having no special way to reset the default values on various effects so when you bring them on they are in the range that you would use them.
    Another major flaw I have on mine is the SAVE "Bundle" and "Preset" function, simply does not work, Acts like it saves the file, try to reload it or open it and it is empty, everything changed to "new tone". Not anything I am doing just is not saving the files correctly. Anyone seeing this??
  • Matte04 Just Startin' 1 posts since
    Apr 3, 2011
    122. Apr 26, 2012 5:46 AM (in response to deanesque)
    Is it possible (and how) to use HD500 for recording DI tracks ? Or I need to get additonal DI box...?
  • Iknowathingortwo 1,667 posts since
    Jul 17, 2007
    123. Apr 26, 2012 12:09 PM (in response to deanesque)
    I thought I would post a copy of my reply from the "Why did Line 6 Stop Making Vettas Forum" here since this is a forum entitled "What Every HD500 Owner Needs To Know".  I thought this reply would qualify based on many questions and discussions in other Dream Rig, POD HD, and DT50/25 forums...
    Here's a photo of my rig with my 2003 Vetta sitting on top.  When in 2006 I got my first Variax guitar, I was able to easily purchase the VDI interface for my Vetta.  It's a very easy install as well since Line 6 planned for it in advance and there is a blank panel with just one ribbon cable that needs to be reroutedinto the VDI panel, then plugged back in.
    Since 2007 when Line 6 "officially" stopped producing Vetta II amps and spent nearly all their amplifier development time with Bogner upgrading the Spider amp line, while also developing the POD HD/DT line of products were designed.  While a completely different team took over the design of the JTV guitar line from the original Variax designers a Line 6.
    This last sentence is just a guess...but considering nothing new was done from 2005 when the first Variax guitars were introduced until the latest 1.81 upgrade which included (3) 6-string & (2) 12-string modified acoustic guitar models from just that one bank.  Oh, I should mention (all of which are just my opinion) that the modeling of all guitars ranges from greatly improved to slightly improved with the original 1.70 software that came with the first batch of JTV line of guitars.
    I felt the most improved were the acoustic models in 1.71, and least improved were the Rickenbacker electric 12-string guitar models from the original Variax guitar models.  I'm sure that this will be addressed in some future JTV update.  Right now, resolving the alternate tuning problems with the new acoustic guitar models is most likely the top priority for the techs working on this aspect of the JTV guitar modeling.
    If what you've heard is true about newer version of the Vetta amps being produced in the future...I'll look forward to that day with great anticipation.  However, if you have the time, the desire, and the finances (or payment plans in my case) - I suggest combining the two as I've done with the older Vax guitars and the new JTV guitars.
    I've also added a pair of Roland GR-55 units since they are truly excellent units, relatively small price tag for their capabilities, and the GK-3 pick-ups for both my older Variax guitars connect to one GR-55 in Guitar Mode and one GR-55 in Bass Mode for my 6-string Tobias bass.
    I honestly can't think of anything more I could use beyond this collection of gear.  I know there are other modeling units available, but I've not had any opportunity to do more than watch demo videos and read what others think.  I started my exclusive Line 6 guitar use such a long time ago, and after all this time and financial investment - I can't see any reason to switch to a completely new guitar system.  Most importantly, I'm very pleased with all I was able to compile over the years allowing me to play nearly any sound I wish as well as any style of music I'm capable of.
    I also just posted a 2-part demo of the Line 6 Dream Rig in various acoustic modes to respond to a request asked of me in the Dream Rig forum.  Heres a photo of my rig, plus a link to my demo/instructional videos if any here would wish to check out just one aspect of the new Line 6 gear in action without any additional gear.
    http://www.youtube.com/watch?v=2gpJHrGdkEU
    http://www.youtube.com/watch?v=vLc1FToEkwk
    And the photo....
    I hope this gives food for thought.
    Take care,
    Neal
    Mar 24, 2012
    124. Apr 26, 2012 7:05 PM (in response to MerlinFL)
    Sweet. Rather an infinite supply of busy and tweaking going on there. Where do you put the kitchen sink and wet bar attachment? Bass pedals, my god, I always wanted some of those.
    I would love to have a new synth. I had the previous model and loved it. I had that puppy running in L/R stereo through the effect returns on 2 twins w my main Marshall delivering the main heavy tone of the guitar. You should have seen the faces on the band and others when I tracked this huge human choir tone paired with my heavy distortion. Think Diary of a Madman on one guitar. God I miss that puppy. I could drag out the old one and remount a pickup but I would rather test drive the new one. My budget just died this month with my wife taking another pay cut, no more gear for me for awhile, lucky I had just got my new POD HD rig setup. Have not understood how to do pics here yet. So was the Vetta another processor model? I love a couple of the effects they put in the POD from that, the wah and the juice are quite good.
  • eldannydemex Just Startin' 6 posts since
    Sep 25, 2011
    125. May 22, 2012 7:01 PM (in response to mazuwa)
    hello there is it posible that u can tell me how i can put the original performance view screen on the pod
    i accidentally do something and now the screen dont show all the effects that i have on the any patch but only the top 4 from fs1 to fs4
    fs 5 to fs 8 are to change patches on the bank.
    please help.
  • Currently Being Moderated
    126. May 23, 2012 9:34 PM (in response to eldannydemex)
    Keep clicking the View Button till you get the View you need.
    EDIT: Silverhead has a Good Point there.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    127. May 23, 2012 5:29 AM (in response to eldannydemex)
    Press and hold the VIEW button to enter Setup mode. Change the FSMODE parameter value to FS5-8; it seems like your current setting is ABCD. This global parameter adjusts the behaviour of the bottom row of footswitches - they can be used to select presets A-D in the current bank, or to operate as FX footswitches 5 to 8.
    Mar 24, 2012
    128. May 24, 2012 8:31 AM (in response to deanesque)
    One of the cool feature of the unit is the ability to use the bank up and down switches to get the group of 4 one wants then use 5-8 to hit the preset you want.
    Having the unit set to effects on/off for 5-8 reverts right back to that setting after selecting the new preset.
    I always keep my view set to see which of the 8 switches are on or off. I always set my configuration switches to an order that makes sense for me from preset to preset. I use 1 for wah, 7 for delay and 8 for reverb while the others follow the order of the chain in the preset.
    By the way, the heavy duty Mission L6-1 expression pedal is really great for that old style heavy duty wah feel.
  • tommygunn Just Startin' 20 posts since
    Jun 11, 2007
    129. Jun 13, 2012 9:44 PM (in response to deanesque)
    Hope I am not out of line or highjacking here but has anyone ever tried using the ZT Lunchbox amp with the Pod HD 500?  I don’t gig anymore and am a little to old to be carrying the heavy amps…lol.  Loved my Spider 75, dropped to the 30 and even that is heavy to carry….well for me it is…haha.   Anyhow, I just go to my local jams now and would love to use my JT Variax with my Pod HD 500 but instead I am using a Fender G-Dec 3/30 watt and the Variax because it is fairly light to carry.  I am now plugging the pod into the aux in of the G-Dec, so I am just wasting the amp by only using the aux in.
    So back to my question, is anyone familiar with this little amp and if so how does it sound with the Pod 500?  It was nice just walking into the jam with my amp in my left hand and Variax over my right shoulder.  I would like to be able to walk in with my Pod 500 and amp in my left hand and JT Variax over my right should.  So am I asking for to much?   lol
    Thanks and again I am sorry if I posted in the wrong area.
    Tommy
    Mar 24, 2012
    130. Jun 15, 2012 2:23 PM (in response to tommygunn)
    The potential of the HD POD is relative to what one uses to amplify it. At least w that lunchbox you have all the watts in the world, which is always a peave for me when dealing with the ever popular low wattage amps. It gets tiresome trying to explain and/or argue that the basis of loudness is not wattage, and "loudness" only increases 3db to every doubling of wattage power. The olnly thing I have heard about the lunch box series is some do not like the tone but they say the overdrive is OK. I would not listen to most reviews especially since the POD processor is an entirely different animal. I find most reviews in general to be quite badly rendered. Have to love the ones about the HD POD where they try out a factory preset through whatever guitar or amp they happen to be using and find it not all that great to their expectations. Really?? Play a model through my rig and close your mouth after the jaw drop.
    That being said the lunchbox is still a small size speaker which limits bass response somewhat and I am also not a huge fan of single speakers. Now 2 little amps allowing the POD to run a true stereo feed is a cool thing. I hear great things about the Line6 DT amps which are small but sound great, they do make a nice 2x12 model w decent wattage but the end result is still mono. Tube amps are heavy due to the transformers required.
    Convience, easy set up and carry is a compromise to ones overall sound and tone. Do what suits you. I know what works best but that tends to get ever so more difficult to carry and setup. I am not playing or jamming w anyone these days so it is of no concern to me. When I did haul my rig it took the better part of an hour for me to load in and set up. But the tone was killer.
    Maybe try leaving your amp rig at the practice area or perhaps if you chaps use a PA, just pipe the POD into the PA mixer. Again mono works but stereo is always better. As to be able to carry everything in one trip, I am afraid that is not something I have ever experienced as I often carry 3 or 4 guitars. I am also partial to my beloved 4x12 cab. Now my power amp and BBE unit, that is an easy carry. When I got my new HD500 I wanted to experiement with the unit to see just how far it could go and just how good one could get the amp models to sound. I built a special rig just for it, although I had to compromise on the issue wanted 2 cabs for a wider stereo spread and I use my 4x12 split wired, which works but isolation is better. Now that I have experienced the full elements of stereo panning and dual amp options on the POD I would not be happy w a mono config.
    Jun 11, 2007
    131. Jun 19, 2012 6:24 AM (in response to anglepod)
    Thanks anglepod for your reply and great info and sorry for the delay in responding but I have been away for a few days.  Anyhow my biggest reason for inquiring is the weight and as I only play at jams were there isn't always a PA system to patch into I take my GDec.  I get a great sound out of the aux input but as mentioned .... a total waste of a decent amp.
    So back to my original question    "but has anyone ever tried using the ZT Lunchbox amp with the Pod HD 500".  I am real curious to know how it sounds so this is really what I am asking.  I do realize that it is only a small speaker but  it may do for what I need and help this old man with a bad back....lol.
    Thanks again,
    Tommy
    Mar 24, 2012
    132. Jun 20, 2012 1:12 AM (in response to tommygunn)
    I cannot see why that lunchbox or the 60watt TECH21 engine speaker would not work well. I like the watts on that lunchbox but what a small speaker in that puppy. I have always been partial to 12" guitar speakers and preferably twins or my beloved 4x12. Had I really not had my great cab I would probably have tried a pair of the TECH21 engine speakers for good wattage, 12" speakers and stereo spread.
    I miss playing with the band but my life sort of moved into a different direction and I cannot deal with the lifestyle or the type of cats I ended up being around. When it stopped being fun the soul pretty much went out of it for me. It was fun playing and a labor of love to haul the gear and setup but I am pretty much retired at this point and just play because I love the guitar. Seems like you eventually reach a point where delusions of stardom seem ridiculous to ponder. I could not handle that teenage high school mentality in some self destructive fools. Maybe at some point I will run into some players who would like to jam, maybe some heavy fusion. but I do not lose sleep over it.
  • joel_brown Just Startin' 90 posts since
    Nov 26, 2006
    133. Jul 8, 2012 2:55 PM (in response to deanesque)
    I just bought the Pod HD Desktop and it has the same issue.  I have to set the Input1 to Guitar and Input2 to Mic.  Then it works much better.  Until reading this post I had reduced the input impedance from 1m to 70k which helped.  This info should be in BIG HUGE LETTERS stating how important this setting is.  I was getting very frustrated with the HD, now I understand and love it.
    btw - big thanks to the Line6 guys.  It takes time to learn and tweak the HD but I'm extremely happy.  I've spent well over 20 hours just getting a handful of presets to work the way I like, but in the end they can out the way I wanted them to sound.  The almost endless combinations that can be put together is great.  It's hard to believe they can put out a product this nice for such a low price.
    Mar 24, 2012
    134. Jul 7, 2012 1:56 PM (in response to deanesque)
    I think in general the more one digs into the unit the more interesting it gets. I actually have about 10 sheets of info on my wall for reference of DSP useage, which are true stereo, a param list chart someone did, and a few progamming tips as I cannot remember them all.
    I experienced a lot of hiss when I first rigged up the unit. Changing the secondary input to one you are not using helps cut some noise, setting on "same" always seems to add hiss. I got the best results splitting my pre POD chain feed at the last pedal to feed both the Guitar & Aux inputs, that is the best of all scenerios.
    I also caution new users on their presets not to over output level the various effects as this adds a ton of noise floor hiss and digitial clipping. The old school of thought regarding "signal to noise ratio" like you would slightly boost the level on your pedals into another is a different animal on the POD. It takes very little level issue to properly work and I think one will find if they keep the levels more unity the results will be better. A good test of a preset is the noise floor with the NR gate off, a little on higher gains is just normal but cleans should be relatively quiet. Exceptions are of course diliberatly hitting the amp front end for overdrive, BUT, the amount of boost needed is not like using pedals into a std amp. I use external compression, clean boost, overdrive, and higher gains for options before the POD and they all work against the amp front end very much like a tube amp responds just set moderate level. I have seen some "user" presets which will gain the outout of an effect all the way up into the amp model for overdrive, way too much, shut off that gate and run from the room hiss. This is a digital unit and it is not that digital is a bad thing I just think sometimes the thinking of analog and normal pedal to amp ideology is misplaced.
    My recent POD rig using a power amp. All the front end pedals are set at unity level or the clean boost on the Radial buffer is like 10db maybe. (Wire mess has been cleaned up.)
    http://www.gearslutz.com/board/members/darkhorse-albums-july2012-recent-pod-hd500-rig-updates-picture8486-july2012-001.jpg
Bookmarked By (18)
