1 ... 9 10 11 12 13 Previous Next 57502 Views 190 Replies Latest reply: Apr 12, 2013 2:48 PM by Gorealex RSS Go to original post
  • jasonk931 Just Startin' 40 posts since
    Sep 14, 2012
    165. Nov 26, 2012 6:02 PM (in response to deanesque)
    Re: What every HD500 owner needs to know!
    Help! I'm a Pastor and play rhythm guitar on the worship band. I use primarily Les Paul's, but recently got a Cherry sunburst Variax. On the clean tones, I'm getting the same arc and crack in the tone. A signal peak of sorts, even when I adjust volume levels:
    My question to you is can you break down step by step how to set the inputs correctly as you stated? Would be greatly appreciated. I love the HD 500, and have found some amazing tones on the Customtone page, but I need some tweaking to dial it all in.
    Also, on my volumes, in the pan setting on a certain tone, do I set the pan at 50% right and the other 50% left or all at 0 in the middle? Help....
    Sep 14, 2012
    166. Nov 26, 2012 6:14 PM (in response to deanesque)
    Ok, I figured the input part out, now my question is, input 1 and input 2? Are they seperate jacks, or I this just a reference digitally?
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    167. Nov 27, 2012 12:56 AM (in response to jasonk931)
    Two jacks on the back of the pod.  One labelled 'Guitar Input' and the other labelled 'Aux Input' IIRC.  Not directly beside each other either (which is moderately confusing).
  • greghall Just Startin' 160 posts since
    Feb 2, 2007
    168. Nov 27, 2012 1:15 AM (in response to jasonk931)
    Hi Jason,
    I would pan to center (i.e. 50% right, 50% left), unless you are using stereo effects and connecting to seperate channels on your PA. If you are playing through an amp, or other mono situation, center position is the best approach.
    There are 4 inputs on the HD500: guitar in, aux, microphone and Variax, and both input channels 1 and 2 can be set to one or any combination of these.
    You can also set input 2 to the "Same" as input 1, but this gives a stronger signal (effectively doubled), so you may want to try setting it to aux or mic, to help with your clean tone.
    Hope that helps
    Regards
    Greg
  • snhirsch Just Startin' 67 posts since
    Oct 17, 2012
    169. Dec 2, 2012 10:21 AM (in response to deanesque)
    A BIG thanks for this tip.  I am a very recent HD500 customer and have been fighting all morning with an obnoxious "double-note" overtone from the G-string on my Variax JTV-69.  It was particularly evident with high-gain on the Marshall emulation and was starting to sour me on the unit.  At first I thought it was the piezo transducers reacting to fret buzz, but it was just as bad when I switched to the magnetics. After tripping over this thread, I changed Input 2 source to 'Aux' (nothing in my case) and - bingo - it's gone.
    I'm not quite sure I understand the underlying mechanism, but if it's a matter of overloading the A/D converter I would think this could be dealt with by adding an internal level reduction when both inputs are active ("same").
  • lachinelli Just Startin' 17 posts since
    Jul 25, 2012
    170. Dec 13, 2012 9:47 AM (in response to deanesque)
    Thanks for the tip. Maybe this is the first thing that made me feel dissapointed from Line 6, and they still haven't solved it. 99% of the time we'll play with one input only...so why double the input??? At least they should update the advanced manual and explain this issue.
    I'm a metal player, so I had everything top notch. Even if it has lost a bit of gain, sounds more defined. I still haven't tried it in amp emulations since I go straight to a real amp.
  • JohnnyFu Just Startin' 8 posts since
    Dec 14, 2011
    171. Dec 14, 2012 3:31 PM (in response to deanesque)
    I sold my POD HD500 a year ago. I got myself a new one these days and I'm quite surprised this topic is still active.
    As I work in IT I understand how development works, fixes and improvement take time, the fact this topic is still active for over a year worries me a bit though. However, I'm a casual player lacking the knowledge to really judge on it or blame Line6. However, even my casual ears noticed sometimes things just sound broken on the POD.
  • hurghanico Just Startin' 399 posts since
    Jan 28, 2007
    172. Dec 17, 2012 11:05 AM (in response to lachinelli)
    lachinelli ha scritto:
    ...that made me feel dissapointed from Line 6, and they still haven't solved it. 99% of the time we'll play with one input only...so why double the input??? At least they should update the advanced manual and explain this issue....
    they have not yet solved it and will never solve it in the future simply because there is nothing to fix ..
    do not believe it?
    ok!
    set input 1 to "guitar" and input 2 to "Variax" .. (
    reverse this setting if you connect a variax)
    you know very well that in path A can arrive only input 1 .. ok .. put an amp in path A and set pan A to the center,.. play and memorize that sound... if you want, do a recording of this sound with your DAW for a later comparison ..
    now move the amp to pre-split position, return pan A to the left,.. play .. is the same sound as before? .. no, I would say no .. is quite weaker and less distorted .. or not?
    Q.: why? ..
    A.: because it lacks half signal, namely the Right side which should arrive from input 2 ..
    Q.: why?
    A.: because when you put a mono effect or an amp in pre-split position, inputs 1 and 2 are reconfigured as L & R of a single input signal, hence the need to have a setting "same" for input 2 to reconstruct the full signal ..
    Q.: why the hell inputs 1 and 2 should be reconfigured as L & R of a single input signal when a mono effect or amp is positioned in pre-split path?
    A.: good question!..
    - input 1 and 2 are two fixed virtual inputs that exist only to give you the possibility to feed simultaneously 2 separate amps/fx with a single instrument or with 2 separate different instruments (as a example let say: guitar and voice), and therefore in the case of 2 separate amps/fx in path A and B, each input naturally must provide a full signal to the amp and fx on its related path..
    - BUT, since the virtual inputs are always 2 (fixed!), and since it would not make much sense to send 2 full signals of the same instrument (or even
    alternatively 2 different instruments signals) both to 1 mono effect or amp that was instead positioned in pre-split path, the 2 inputs in this latter case would be reconfigured as L & R of a single-(supposed and expected) physical input signal ..
    - therefore, still in this latter case, if the 2 inputs are instead set different-(unexpectedly) from each other, you get only the L part of the instrument set on input 1, and the R part (if any active,.. let say: your invented "null" option) of the other instrument-(dummy or not) set on input 2.. both theoretically feeding the same amp or mono fx in pre-split path position..
    Q.: who told you that?
    A.: nobody, I figured it out by myself after many experiments and sound comparisons and I am convinced that it is like just explained, as I am convinced that.. yes, and here I agree with you, the manual could have been written a little better ..
    obviously if some people, like you and the other posters in this thread, prefer more the sound of the POD that they get with a halved
    input signal, everyone have their own tastes and are free to do as they want..
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    173. Dec 20, 2012 12:08 PM (in response to hurghanico)
    I just saw this comment now, and I think you might be misdiagnosing the signal drop here. I don't think the drop in signal you're hearing has more to do with the pan settings and where you have the amp block. If you have the amp block before the split, the left side of its output will be going to Path A and the the right half will be going to Path B. Btw, do you have Path B muted in the mixer here? If you do, you will only be hearing the left side of the amp block's output. That would explain why the signal wouldn't be quite as loud as having the amp model in Path A. In your first scenario - amp block in Path A, Pan control centered, you'd be getting the full stereo output of the amp block.
    That is one quirk of the HD500. Even though there are mono effects and amp models, they really function as mono in/stereo out. Another quirk is that pan control really isn't a true pan. It's a balance control. When you pan to the left, you're not moving a mono signal across the stereo spectrum. What you're really doing is turning the right side down. When panned center both left and right are at 100%. When panned hard left, the left is 100% and right is at 0%. Vice versa is panned hard right.
    Jan 28, 2007
    174. Dec 29, 2012 10:14 AM (in response to phil_m)
    phil_m ha scritto:
    I just saw this comment now, and I think you might be misdiagnosing the signal drop here. I don't think the drop in signal you're hearing has more to do with the pan settings and where you have the amp block. If you have the amp block before the split, the left side of its output will be going to Path A and the the right half will be going to Path B. Btw, do you have Path B muted in the mixer here? If you do, you will only be hearing the left side of the amp block's output. That would explain why the signal wouldn't be quite as loud as having the amp model in Path A. In your first scenario - amp block in Path A, Pan control centered, you'd be getting the full stereo output of the amp block...
    in the experiment above, when the amp is in path A, the pan settings in the center serves only to not have to uncomfortably listen only to the left side (just for ease of listening), and not for the demonstration of what has been said, which is entirely based on the relationship between the input settings and the possible amp positions...
    I have not muted path B because it was useless, since input 2 was set to a dummy instrument .. therefore when the amp is in path A there is no risk of hearing also the dry guitar signal through path B to confuse things..
    that said, (regardless of the pan settings), when used with only 1 input, the amp sound in pre-split path position is weaker and less distorted..
    when using instead both inputs for the same instrument, the amp sound in pre-split position is exactly the same (volume level and distortion level) to when it is in path A..
    This is more than enough for me to prove the validity of what has been said before
  • CairnsFella Just Startin' 205 posts since
    Sep 16, 2012
    175. Dec 27, 2012 4:26 PM (in response to deanesque)
    Line 6.
    Please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please, please chip in and confirm the facts of this issue once and for all!!!
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    176. Dec 27, 2012 4:52 PM (in response to hurghanico)
    hurghanico wrote:
    I have not muted path B because it was useless, since input 2 was set to a dummy instrument .. therefore when the amp is in path A there is no risk of hearing also the dry guitar signal through path B to confuse things......
    Paths A and B do not correspond directly to Inputs 1 and 2. If there is any amp/FX  positioned before the path split then each of Input 1 and Input 2 are routed to both Paths.
    The only way to isolate Input1 in Path A and Input 2 in Path B is to make sure that there is no amp/FX placed before the path split in the preset.
    Also, both Paths are stereo.
    Jan 28, 2007
    177. Dec 29, 2012 10:16 AM (in response to CairnsFella)
    CairnsFella ha scritto:
    Line 6.
    All work and no play makes Jack a dull boy All work and no play makes Jack a dull boy All work and no play makes Jack a dull boy
    All work and no play makes Jack a dull boy All work and no play makes Jack a dull boy All work and no play makes Jack a dull boy..........
    Line6 listen very carefully to me!!!!
    here the situation starts to become worrisome!!
    you've seen the movie "The Shining"?
    Yes? .. Ok .. very well!
    since in this forum we do not want our friends to go crazy like Jack Nicholson in the movie and begin to write the same words endlessly, please give us finally an official version of how the things are ..
    personally, at this point, I do not longer feel the need, but for sure a reassuring official version would certainly be appreciated by most people here..
    therefore please be good and do this little effort once and for all!!!
    Thanks in advance
    PS.
    CairnsFella in here you are one of the most sympathetic people ..
    and you have surely realized that above I'm just kidding..
    Jan 28, 2007
    178. Dec 27, 2012 5:47 PM (in response to silverhead)
    silverhead ha scritto:
    ...Paths A and B do not correspond directly to Inputs 1 and 2. If there is any amp/FX  positioned before the path split then each of Input 1 and Input 2 are routed to both Paths.
    Also, both Paths are stereo...
    very true, I never said otherwise ..
    In fact, in my demonstration I am referring clearly to what happens when something mono is in pre-split position ..
    when there is nothing
    mono in pre-split, in A path arrives only input 1, and in path B arrives only input 2 ..
    in this situation the amp in path A (separate) to be identical to when it is instead in pre-split, it needs both inputs to be the same (when it is in pre-split)
  • Akeron Just Startin' 224 posts since
    Jul 23, 2011
    179. Dec 28, 2012 5:27 AM (in response to hurghanico)
    Try emailing them (a long distance phone call is out of question!). Maybe if you insist enough they will be desperate enough to answer that question in a meaningful way...
Bookmarked By (18)
