1 ... 9 10 11 12 13 Previous Next 57410 Views 190 Replies Latest reply: Apr 12, 2013 2:48 PM by Gorealex RSS Go to original post
  • hurghanico Just Startin' 399 posts since
    Jan 28, 2007
    180. Dec 29, 2012 10:10 AM (in response to Akeron)
    Re: What every HD500 owner needs to know!
    Akeron ha scritto:
    ...Try emailing them (a long distance phone call is out of question!). Maybe if you insist enough they will be desperate enough to answer that question in a meaningful way...
    personally I don't feel anymore the need to obtain further confirmations ..
    but for those who want to try to get a official explanation, I can suggest them a secret trick:
    you want to know how to directly contact who wrote the manual?
    Calm down! you are too many! one by one please!
    ok, click with the mouse right button on the manual file icon, it opens a menu, choose "properties", click on the tab "PDF",
    now you can read the name and email address of the author ..
    to be honest, seen how he wrote the manual on this topic, I do not know if he has completely understood the way the things are, I hope so, I think it would be probably more exhaustive to speak to one of the HD programmers.. and unfortunately at the moment I don't have more secret tricks to reach them too..
  • CairnsFella Just Startin' 205 posts since
    Sep 16, 2012
    181. Dec 29, 2012 7:51 PM (in response to deanesque)
    I should probably clarify after my previous post that I am honestly quite happy with hurghanico's explanation of the way things are. My pleading for line 6 input is becuse despite this, everytime the issue gets discussed I cannot resist the urge to reconsider the issue and review the points presented.
    If there were a clear official stance I'd be more inclined to relax (at least until someone comes up with evidence that contraditcs that stance ... and possibly why they dont).
  • perapera Just Startin' 40 posts since
    Jun 19, 2010
    182. Jan 2, 2013 4:57 PM (in response to meambobbo)
    sorry meambobbo I didn't come here for a long time...
    I repeated the test:
    sine wave > audio card out > pod blank patch* > audio card in
    (* with both mixer channels at unity and pan-centered)
    I recorded the same thing two times, one with only input 1 active (input1: guitar; input 2: variax) and one with both inputs set to guitar
    then I gave 6dB on my daw to the first one and inverted the polarity:
    well... they actually cancel QUITE perfectly; the resultant is a sine with 50dB less than the original,
    but I checked the two waveforms which are exactly in phase up to the sample level,
    so I think the quite-complete-cancelling could be due to a not-exactly 6dB difference and frankly I can live with that
    then I did the same thing introducing a noise gate in the "pre" path with the threshold at 0% and obtained the same result
    if you use a distortion with 0% drive it doesn't mean "no distortion" but "minimum distortion (for that pedal)", so halving the signal that you send at its input gives you less overdrive and doubling it gives you more overdrive that's all
    BUT, and this is a BIG FAT BUT, I now agree that it's better to use a Guitar/Same input configuration
    please read this thread I started:
    http://line6.com/support/thread/90441
    bye
    Lore
  • Vadzer Just Startin' 1 posts since
    Nov 27, 2012
    183. Jan 18, 2013 7:25 AM (in response to deanesque)
    Hi guys. I have the same problem with my POD HD 500 http://www.youtube.com/watch?v=rFIUR-2njnQ  tell me please how to fix this ****????????
  • bjnette Just Startin' 82 posts since
    Sep 2, 2012
    184. Jan 22, 2013 7:00 PM (in response to Vadzer)
    I do not have the problem but I have the latest firmware installed. Also I actually name a preset. Do not know if that'l make a difference. Hope so for your sake! Cheers
  • sonas Just Startin' 22 posts since
    Dec 30, 2012
    185. Jan 30, 2013 1:51 AM (in response to deanesque)
    Hi
    Thanks for posting this. I already us a JTV 59 variax with VDI cabel, so what do I set channel 2 to if I have ch+ set to variax.
    All the best
    Sonas
  • svetlosivilo Just Startin' 4 posts since
    Dec 6, 2008
    186. Feb 18, 2013 8:57 AM (in response to sonas)
    Hi
    did anyone notice that Multihead Delays on POD HD are mono?
    is that some kind of joke?
    ******* POD X3 and even XT have multihead stereo delays?
    so are multihead delays mono or i am stupid ?
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    187. Feb 18, 2013 9:11 AM (in response to svetlosivilo)
    The multihead delay is a stereo thru/mono effect block. What that means is that it will maintain a stereo separation through the effect block, but the effect itself is in the center of the stereo field. It's the same way it is on the M13. A comprehensive list can be found here:
    http://line6.com/support/message/380853#380853
  • ciurli Just Startin' 3 posts since
    Aug 23, 43433
    188. Mar 17, 2013 1:19 PM (in response to deanesque)
    Thanks a lot
    Really better
    SC
  • eterealmetal Just Startin' 1 posts since
    Jul 21, 43435
    189. Apr 10, 2013 10:14 AM (in response to DeanDinosaur)
    POR FAVOR AMIGOS AYUDENME TENGO UN POBLEMA CON MI POD HD500, LO QUE PASA ES QUE POR MAS QUE INTENTO NO PUEDO SACARLE UN BUEN SONIDO, LE FALTA MUCHA FUERZA, DEFINICION Y BRILLO, Y CUANDO PONGO DISTORSIONES HIGH GAIN SUENA HORRIBLE, CUANDO EJECUTO RIFFS LA DISTORSION TIENE UN SONIDO FUZZ, POR FAVOR AYUDENME.
  • Gorealex Just Startin' 2 posts since
    Jul 13, 2006
    190. Apr 12, 2013 2:48 PM (in response to eterealmetal)
    Que raro! La verdad que a mi me a funcionado medianamente bien desde que lo compre ( 2 semanas atras ) . No se puede comparar al 100% con un ampli real , pero hace su trabajo .De todos las simulaciones de amplis del POD HD 500 las que si he encontrado "un poco FUZZIES " es la del JMC 800 Y la del SOLDANO SLO Drive Channel.Pero a pesar de eso , se puede trabajar con eso y con un poco de " tweaking" ya se consigue lo que se esta buscando. Utilizas audifonos o tocas atravez de un ampli?? . Que clase de pickups tiene tu guitarra?? . Pickups baratos , tienden a sonar mal y asi toques con el mejor ampli no vas a conseguir el resultado deseado .Ayudaria si pudieras subir un tono tuyo hecho en tu POD HD 500 al " customtone " para poder ayudarte y tratar de entender lo que pasa. Tambien seria bueno saber que clase de " sonidos" te gustaria crear. Veo que tu Nick es " Eterealmetal " . Supongo que el Metal es lo tuyo. Asi que con el POD HD500 pudes conseguir buenos tonos tipo METAL sin que resulten muy FUZZ o sin definicion. Espero tu respuesta con algo mas de informacion.
Bookmarked By (18)
