Currently Being ModeratedRe: What every HD500 owner needs to know!
lindsayward wrote:
kvines, it's up to you if you want to send the guitar to both signal paths, as described above (then use guitar).
I thought that for this on the HD bean anyway you would generally set Input 1 Source to GUITAR and Input 2 to "SAME" - effectively routing the guitar input to both processing channels - is that not the best approach?
- Report Abuse
Like (0)
I think the thing to keep in mind is that both signal paths are stereo....Whether or not you would need input 2 set to "Same" or "Guitar" (same thing on the bean) depends on whether you are using dual tones or not....However, you can use it to push a single amp model harder in single tone patches if you like...But in this case you might need to exercise some caution as some FX model clipping if you over drive them....A really good example of this is the Tape Echo...You can saturate the crap out of the tape and the clipping sounds pretty realistic to my ears...
Basically, whatever approach gives you the results you are looking for is the correct one...In general, I set Input 2 to "Mic" for single amp tones and "Same" for Dual amp tones....However, I do like using the Same option for the Engle, Dr Z and a couple of others...Mainly because I kinda like getting a tad more breakup with the drive set just a little lower...Although the end result saturation is about the same, the tone and response is a little different...kinda like using a clean screamer against a real amp...just more tonal option I think...
- Report Abuse
Like (0)
Wow! My patches sound so much better.
- Report Abuse
Like (0)
Guys, correct me if I'm wrong but:
1) When we set up input1=guitar and input2=same, POD doesn't use any other hardware input - it just splits your input1 into two flows (A and B). So when you use stereo effects your signal will flow both A and B directions.
2) When we set up input1=guitar and input2=Variax POD uses your guitar signal for A flow and Variax hardware input for B flow. It means that you have "nothing" flowing into your B flow. So you could hear loss of the certain amount of signal using stereo effects.
Hence the summary of my post: Using input2 set to whatever unplugged input is WRONG.
- Report Abuse
Like (0)
Ideally your statement would be correct if there should be an option that sets either input to nothing. your statement is not correct because if you use guitar for 1 and 2 and you're not using two discrete paths, then your signal ends up being doubled so the consensus is setting input 2 to variax is the least noisy.
- Report Abuse
Like (0)
That's not correct. Check the manual in the Inputs section where it describes the Input Source Routing for the HD500. While it is possible to arrange your preset so that Inputs 1 and 2 are seperately assigned with Paths A and B respectively, this is not usually the case. Input 1 is often routed through both Paths. Each of Paths A and B is a stereo path.
- Report Abuse
Like (0)
So are most of us agreed that for most users it's best to set input 2 to Variax?
- Report Abuse
Like (0)
I like the idea of the global input assign but I wish to heck that you could override it for individual patches. I think it is all about scenarios.
- Do you get distortion even on clean channels?
- If yes - Input 1: Guitar and Input 2: Variax.
- Do you get excessive noise/hum when using a high gain amp model (or running 'effects only' into a high gain amp).
Do you lose half the soundscape on stereo effects in certain patches
- If yes - Input 1: Guitar and Input 2: Same. or reassign the routing so that it plays nice (as per Silverhead comment above)
The bottom line is that ... it depends
. I default all of my patches manually to Guitar/Variax but it is no big deal to reassign if needsbe. I will not be using the Global.- Report Abuse
Like (1)
I'm pretty sure you can save input assigns per patch and with 1.4 you can also save input impedance per patch though I just leave mine on default auto.
- Report Abuse
Like (0)
I'm not sure what you guys are referring to here when you say you "have to do this in every patch" because the inputs are a global setting. As far as I know, unless you're using HDEdit, it's a global setting.
Edit: Check that... I was under the impression that when you hold down the View button to go into the settings menu that these were "global" settings. But to my surprise, they are indeed per patch. That makes sense I guess... but wow, what a pain! Especially if it causes a problem. I've never had mine set any other way but this "wrong way" and i've never noticed my sound being all that bad. I'm about to try it with the Input 1 set to Guitar and input 2 set to Variax (since I do have one!).
Does anyone know if the "Best of HD 500" presets have EVER been tweaked by Line 6? Or are they basically the same exact ones from when the unit was brand new? Some of those tones are beyond ROTTEN and I can't imagine that anyone would even consider using them. To each his own I guess!
Jason
- Report Abuse
Like (0)
As of firmware v1.40 the Inputs setting is either global or per preset - your choice.
- Report Abuse
Like (0)
You are right: you have the options to either go 'Global' in which case you assign the same Input Configuration and/or Input Z to all patches or 'Preset' in which you assign them to individual patches.
I was arguing that it would be convenient for me to use 'Global' to set to Guitar/Variax but then still being able to override - i.e. an exceptions-based approach - for specific patches..
Effectively the global setting pre 1.40 was Guitar+Same+Mic+Variax+Tintray+Kitchen sink and we overrode it with presets. I would like to go the same way but have a choice of what that initial global default was.
... I am just not bothered enough about it to distract L6 with a feature request
- Report Abuse
Like (2)
Wow, is certainly a great tip! I can't believe how much difference that made. I too had clipping tone issues, especially with my strat. It was like my strat's action was too low - I got that buzzing tone. After changing input 2 to Variax, I get a MUCH cleaner and more amp-like tone. Remarkable.
Thanks for this find, I am sure happy for it!
Robert.
- Report Abuse
Like (0)
Thanks for the tip. Wish I would of known this 7 months ago!!
- Report Abuse
Like (0)
I got my PodHd500 Unit 3 months ago, came with 1.31, now it's 1.4 since that's out.
I heard the tip with the Variax in Inp 2 right as I got my unit, so i changed every preset to that and thought it was okay.
Now after reading this whole thread I tried few things with the pod.
Some mentioned if u put inp2 as variax, there would be no dual-settings. I always wondered why it didnt worked when i made a preset with 2 amps, both hard panned. It just worked when I put a Screamer in front of both of them (So, as mono). Now I know why
As someone said the only reasonable setting (when just putting in the guitar) would be guitar/same or guitar/guitar. I tried that just a few minutes ago. Man, that sounds awesome as hell and even Dual-Patches worked now.
And the noise? Clipping? Didn't have any of those, the cleansounds stay super clean and the crunchy fenders crunch like they should. My guitar is a Ibanez RGA72 with active IBZ LZ Humbuckers in Neck and Bridge.
So, my new setting: Guitar/Guitar in global. Thanks Line6Forum, very useful threads!
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Incoming Links
About
Follow
Subscribe
