Currently Being ModeratedRe: POD HD500, HD Pro and HD (Bean) V. 1.40 update available
where can I find this manual?
Only the old manuals are on the site?
I'd love to see a manual with the updated features in it!
Thanks!
- Report Abuse
Like (0)
I've noticed more distortion too, I thought it was simply more digital clipping possibly introduced by the new impedence settings (the sound reminds me of the X3 :/ ) and would just need tweaking of those values, but so far that doesn't seem to have any effect (using very low output active pups to test with). I'm also undecided as to whether I should simply roll back the update, I need to do some a/b comparisons though with both to see if it's real or whether it's just some psychoaccoustic effect.
- Report Abuse
Like (0)
Thanks!
You are right that the POD HD (bean) and POD HD500 Advanced User Guides seem to be the version 1.3x versions, but the POD HD Pro Advanced User Guide is the version for 1.40 so in the short term you can get an idea from that. I'll feed back that the latest manuals seem to be missing for the POD HD and POD HD500 although I suspect they will turn up in the next day or so.
- Report Abuse
Like (0)
I just downloaded the HD500 Advanced Guide: Rev. B, v1.40. I haven't perused it, but did see that it includes the hard gate.
- Report Abuse
Like (0)
Ah good. I literally checked them all just about 5 minutes ago and the Pro was at 1.40 but the other two were still at 1.3. I have raised it for attention, but I guess it was in hand anyway
Nick
- Report Abuse
Like (0)
I'm still working on it.. my go to j800-tread patch sounds like crap now. No input clipping.. seem like more noticeble trailing distortion. I need to spend more time with edit on existing patches maybe.
- Report Abuse
Like (0)
I did the update and do not see the mentioned "new presets or L6Link<>DT" set list on my unit.
I told it not to keep my existing presets. Any ideas.
- Report Abuse
Like (0)
Same here. I have tried both "Yes" and "No" several times; no new presets either way.
Also, the HD500 advanced guide is now revision B while the previous was F.. ..the HD Pro manual seems to be an updated version, though.
EDIT: Should read before write; apparently this is one of the Known issues mentioned in the release notes; The new presets are there, but the set list names are unchanged. Weird, that L6 was not able to change the set list names!!
Ref.:
- Set List Names – If during the update process new presets are optionally loaded to over-write the previous set, Set List names may not correlate to the new presets appropriately. This is because renaming Set Lists is not a part of the firmware update process. Set List names may be changed in the hardware using a variety of methods:
- Manual - Set Lists may be renamed manually by simply highlighting a Set List name and pressing the Save button. Use the four encoders beneath the main display and press Save to complete.
The presets in firmware v1.4.0 correlate to the following Set List names, as seen in the main display from left to right, top to bottom:
BEST OF HD
FX HEAVY
SONGS / STYLE
BASS/ACO/VOC
L6LINK <-> DT
USER 1
USER 2
USER 3
- Report Abuse
Like (0)
Are we missing for HD 500 the HD Edit V1.06? I'm still on HD Edit V1.03 and it doesn't show the New Hard gate, but I can access the Hard Gate from the HD500 Hardwarecontroll panel. Did someone forget to upload the HD edit so we can download? I don't see it in the download page. as mentioned above ^^ Also the latest manual is not there!
- Report Abuse
Like (0)
You're right - looks like the Editor hasn't caught up with the firmware just yet. I would expect it very soon, but I don't know for sure.
- Report Abuse
Like (0)
is it there if you turn off all effects besides the amp? what if you roll down the "amp volume" knob?
- Report Abuse
Like (0)
Yes, I tend to use nearly totally dry patches anyway, just the amp. Though it was more pronounced with my older patches where there were effects too. Not sure what's changed, but it's almost like the signal is being compressed somehow, it's very dead and non-reactive, hard to clean up with different pick attack/volume on the guitar now, it's like the whole unit has changed. Master no longer seems to mix back to the Pre sound either, but it acts more like a real world amp master volume actually bringing volume down to 0 rather than blending, not sure what to make of that. Maybe it's how it should have been all along, but it seems like it's a change.
Dunno, I'll have to play some more, it's odd as I'm pretty sure L6 would have mentioned if any of that stuff had actually been changed/adjusted because it would result in pretty major changes to patches and sounds. I really do need to go back and revert then try out some things see if it was different or if i'm just imagining things.
- Report Abuse
Like (0)
I suggest you start with the new InputZ control in the input setup page...This allows you to match up the impedance of your guitar...I find that the auto setting isn't quite right for a couple of my guitars...I find if I start there I can get my guitar is a bit better shape before it hits the tone stack...I am actually finding that slightly different settings on inputZ with the same guitar has a desirable effect on particular amp models...Generally as you lower inputZ the highend is going to rolloff a bit...This is pretty nice where the treble tends to get a little harsh...This can be saved discretely on each preset if you like...Really a fundemental feature that was needed IMHO.
- Report Abuse
Like (0)
Input Z was my first guess too, and I'll continue to play but so far changing it doesn't seem to make much of a difference for me at any setting. It's odd as based on the release notes that's the *only* thing that's meant to have changed for my and new tones (I already set them up with just single input).
Oh well, I should probably just roll back the firmware and wait for the next update in June.
- Report Abuse
Like (0)
... (sorry guys, won't be 100% happy until we have a real EQ and some more FX amp models in there
for the record of it, quite a lot of people have asked this since day one) - input update (this is cool)
- midi improvements (cool too, but don't use it so)
- presets ???? (what a joke, who uses presets here ?)
- hard gate (huh? come on, why release a lemon when people cry for apples ?)
Hope next firmware won't be 6 months away ....
Cheers,
Hans
- Report Abuse
Like (0)
About
Follow
Subscribe
