Currently Being ModeratedRe: POD HD500, HD Pro and HD (Bean) V. 1.40 update available
I disagree, the update is exactly what I wanted.
1- No point working on anything until the basic input issues were resolved, getting the best transfer of tone and getting rid of noise from 'input 2' etc. were the priority. You get a good tone in before you mess with it, this gives you a better chance and makes it easier to do it.
2 - Presets ARE important, I have a bass and DT-25, can't wait to dive in - I learn from presets. Also, presets sell units to NEW users, more new users = longer shelf life and more developement, its good business and good for current users. There is nothing wrong with using presets, if you find the sound you like then happy days, less time tweeking, more time playing!
I have had my HD500 since it came out, haven't even scrathced the surface yet, I am overwelmed with amps, effects and options- I doin't know where youn guys get the time that want more! I'm realy not getting the EQ thing either- I either record at home and EQ in my DAW or into a PA with an EQ to get the 'room' sound- Its an amp sim and fx pedal sim, now people want it to be a mixing desk
From me - 100% THUMBS UP for this update, no reservations; 2 big updates that add amps, fx and new tools (not just fix bugs) is far more than other hardware manufacturers do.
- Report Abuse
Like (1)
Hi Sean, with all respect, seem that we don't have the same use of the HD
.... if you like your HD as it is, that's cool, I don't think asking for a good EQ is wanting it to be a mixing desk.I use the HD for recording + live (into PA box). For recording I just use the dry models and use fx afterwards, so no problem there, BUT in live i really have a problem with the EQ's and a hard time to finetweak the models so they sound the same as on my recordings.
Maybe presets sell the units, but sincerelly after 28 years of playing guitar, I just want to dial in the sound I have in my head, no need for presets, but I agree they can be a good starting point for some people but that's not priority for me.
And about the amps, I used the JC120 model quite a lot before and really mis it for my Jazz gigs, I made another one with the tweed B-man pre, but it doesn't sound as good, so no, even if I mostly use the Bogner, Elektric, tweed, Marschall and Treadplate, the unit really needs a good model for Jazz.
Cheers,
Hans
- Report Abuse
Like (0)
Just a guess but I would imagine that adding an additional dedicated EQ stage would require a significant chunk of extra DSP?
I am a new HD bean user but have already found that a simple dual amp + spring reverb patch uses so much DSP that I can't add a single tubescreamer in front of the amp pair before the DSP limit is reached. That really surprised me.
Perhaps there is a little bit of spare DSP kept in reserve for updates/safety margin etc but presumably L6 can't add anything that would compromise existing patches so options may be limited?
I guess the new pickup loading facility is comparable to adding an EQ stage (I presume they don't actualy change the physical imput impedance?) - but the HD design is presumably DSP limited in how much extra they can add without compromising what is already available?
Footnote - parhaps L6 should consider adding a DSP allocated meter or bargraph to HD Edit so we can see how near to the limit we are when creating patches. I think that would be very helpful.
- Report Abuse
Like (0)
Hi CIM1, I don't think making a good parametric EQ would use more DSP, they could for example go for a 2-3 band fully parametric so people can use one or two if needed ...
I think I may completely give up hopes for better EQ and buy a TC Electronic Fireworx (or G-System) for better EQ, DYN and timebased FX, so I can actually obtain the same sound live as in my studio and just use the HD for amp models and some basic pre amp FX like wah, phaser etc ... I just saw that a used Fireworx unit is around 400€ and it has pro digital AEB, Optical, SPDIF in/out as well, which can be usefull when connecting to a digital mixer live ...
Cheers,
Hans
- Report Abuse
Like (0)
If your PA doesnt have EQ, I highly reccomend getting a little EQ Pedal (BOSS GE7) as they have very guitar friendly F, they go for under 40 quid on ebay. ART EQ-351 (31 band) rackmount go for 80 quid new...
Sure, Line 6 could model one, but they don't 'have to' (it wasn't an advertsed feature!) and it may take a while...also it will eat a DSP slot for a fairly basic effect.
IMHO, you shouldn't need to EQ a good tone, the shape and sound of what comes out of the amp can pretty much be dialed in at the amp, I'm not saying you can get that tone out of the HD500 witout and EQ stage, I'm just saying you shouldn't have to
I'm playing with the update now with my DT25 and I like what I hear 'out of the amp', but I have never pluged in directly to a PA (without going through a mixing desk with EQ) so I can't comment on the sound that comes out- you could be trying to compensate for the PA or the room; try borrowing a multiband EQ and see (a) If an EQ fixes the sound and (b) how many bands/much tweeking was required?PS- Don't get me wrong, I would also like to see more FX, clean amps, accustic amps, bass amps, who wouldn't :-) It is also interesting that this thing could drift towards being a more convential 'general purpose' effects unit for use with DAWS...
- Report Abuse
Like (0)
Hi Hans - I can't see how L6 can implement a dedicated EQ without using some dedicated DSP - a parametric EQ is not one of the most intensive DSP hogs when used in a patch but certainly would need some. Who knows what is available in reserve other than the L6 designers!
- Report Abuse
Like (0)
+1
I am a huge fan of the Mid focus...It seems to be full bandwidth....It's a bandpass, but just about any curve can be obtained...It's sorta like a Pultec and it's the most powerful one of the bunch...But a two sided bandpass approach is a bit more difficult to get your head around...At leanst in terms of a mastering approach where a smooth response curve is the goal...
The lack of frequencies does make it a little strange to use the EQs and I hope they get those labeling issues people have worked in at some point...but I honsetly found with the HD I need far less corrective EQ as compared to the XT generation...
- Report Abuse
Like (0)
I'm guessing there will be another update within the next couple of months to address the EQ and other requests going by how 1.3 was a major upgrade that was preceded by an upgrade to HD500 only, meanwhile the 300 and 400 didn't get that update. Now the 300 and 400 didn't get the 1.4 so maybe 1.41 will be for everyone hopefully right around Xmas.
This upgrade seems to be to quiet down some of the complaining about the update situation, it's like throwing a bone before your give your dog his big meal
Let's be realistic the input impedence was probably implimented to be "auto" in Frimware 1.3 and if not the default was propably 1mg which is suitable for 99% of patches that don't begin with a WA or a fuzz pedal but it certainely adds to the flexibility. I tried it out and I can sense a dramatic difference in the feel of some of my patches by going from 1m to something else. So it does effect the response and feel and you can sense it with your fingers, but I bet the listeners wouldn't hear much difference. So this great for everyone specially those who like low to mid gain sounds. For the highgainer you get the hard gate, so now you can max out gain and the new gate will clean up the noise much more efficiently.
Overall this is a nice update, but it just seems that it's part of a bigger thing that's yet to come, and if that's not the case and we don't get the EQ or whatever else, still, the HD500 is one of the best tone Machines outhere. As much as I like an updated EQ, I've learned to work around that (Just manage the bass frequencies and you're golden, even if it means setting the amp bass to Zero on many amps and on top of that use a low shelf from the Shift EQ, it's not like it hasn't been done with real world amps after recording them with a mic. To me I view that as authenticity of the models because to get a decent recorded sounds VIA mics from most real amps, the bass is set very low and a high pass or low cut is applied).
- Report Abuse
Like (0)
If the unit wasn't so DSP and effect slot limited, I would agree with you. Ultimately, I want to EQ my tone, so I got my "brown sound", then add effects. When I've EQ'ed the tone to the point where I want, I often run out of either effects blocks or DSP. If the cab/mic emulation included an EQ'ed tone that got the sound a lot closer to ideal, this would partially resolve the issue. Also, if there were stronger EQ effects, we could use less of them (although each effect would likely be more DSP-intensive - on net I'd dedicate less DSP/blocks to EQ though).
Try the Recto amp with XXL 4x12 cab. Even with the SM 57 on axis, you need to fine tune the low end being turning the bass to 0, even if you turn up the other controls. There's a HUGE ~140HZ hump you have to kill to get a usuable sound.
- Report Abuse
Like (1)
Are you testing this on low, mid, or high gain tones? Also would you describe your guitars as dark or bright sounding? Are you using new strings?
I'm asking all this because if you're not hearing a difference in tone, maybe your update was corrupted and you should try to reinstall?
- Report Abuse
Like (0)
What exactly should I be listening for when using the different InputZ? I use mainly high gain patches.
- Report Abuse
Like (0)
from what i've gathered, it should affect high end frequency rolloff and less significantly the overall volume.
for high gain patches, this will change the overall feel/tone of the distortion. different amps/distortion types respond differently to high end. For some ends, a lack of high end makes the distortion sound fuzzier or muddier. For some it smooths the distortion out or makes it less dirty. Conversely, raising the high end will make some amps have a more saturated, harmonically rich distortion, while for other amps, it creates a dirty, crackly breakup in the high end.
- Report Abuse
Like (0)
Some of us old farts have had experience with many of the amps and effects being modeled and have tried and/or owned others which we would like to see represented. Speaking only for myself, I have little to no use for many of the effects present, so there is no sense diving into their options. On the other hand, Line 6 has turned its back on literally a 15 year period of high-gain tone with the exception of the Treadplate which doesn't do much for those of us who aren't into the Nickleback sound.
Regarding the EQ comment. I am not the least bit interested in a mixing desk. I rehearse and play live through a real guitar amp, depending on the HD500 to serve as a preamp w/MFX. The only way I've found to get a decent tone (for me, you know, the one in my head?) with the paltry offering of high-gain models is to EQ them.
I'm happy that you're happy with what you have, but please don't pretend to assume things about people with whom you don't seem to agree.
- Report Abuse
Like (1)
Are you sure about this?!?
Graphic EQ
Inspired by* graphic eq pedals such as the MXR® ten band graphic equalizer which
became an integral part of the live rig of Randy Rhoads.
- Report Abuse
Like (0)
Hi values will give brighter sound and lower values will give darker sounds, but it does change the way your fingers feel as it's not just rolling off the hi or low Frequencies like an EQ.
- Report Abuse
Like (0)
About
Follow
Subscribe
