355 Views 1 Reply Latest reply: Nov 22, 2011 5:15 PM by Line6Hugo RSS
radz108 Just Startin' 4 posts since
Oct 27, 2011
Nov 17, 2011 10:12 PM
What are the preamp tube positions in the DT50?
Recently got a POD HD500 and a DT50 212. I'm noticing that at high volumes (especially on clean tones), I hear a slight crackling/ pinging sound coming from inside the amp. these sounds seem to flare up when I hit a lowish note on my guitar at moderate volumes (almost sounds like a snare drum is rattling nearby when you hit a loud lowish note, but I don't have a snare drum around). Tapping on the preamp tubes with a pencil, I noticed that the preamp tube on the right of me (I am looking at the back of the amp. The caged power tubes are in front of me and the preamp tubes are behind.) pings when I tap it, the tube on the left makes no sound whatsoever.
I was thinking I might have a bad preamp tube so I want to replace both of them. I read on this site that LP tubes should not be used in V3 position. Which preamp tube is the V3 position?
Also what preamp tubes would you suggest to get to replace the ones in the amp?
I do have a bit of a white noise problem (constant irregardless of amp volume) especially with topology III/pentode/ClassA - Would changing the preamp tubes improve the noise issue as well?
Thanks for your help.
RG
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Nov 22, 2011 5:15 PM (in response to radz108)
    RE: What are the preamp tube positions in the DT50?
    The preamp tubes in the DT50 are Electro Harmonix Low Microphonic "EH" tubes and we recommend using those with the amp as replacements.
      As for the white noise, part of it is the way the circuit was designed, part of it is the modeling.  The nature of the amp is that it is supposed to be that way.  It is not a quiet amp.
      Regards,
      Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
