254 Views 3 Replies Latest reply: Dec 20, 2011 3:06 PM by Line6david RSS
talwilkins Just Startin' 79 posts since
Apr 19, 2011
Dec 9, 2011 3:34 PM
Amp B silent in Dual amp mode
When I make a dual amp patch, the second amp will no make a sound. It seems tha signal isn't split at all.
Only if I put an overdrive pedal or some other effects will the second amp suddenly get a signal. Most effects don't have this effect, mind you.
Just some effects will have this effect. Af course I want the singnal split with or without any effect in front of it.
What am I missing? The volumes are all set ok. In the mixer both amps are set to centre (other settingsdon't solve the problem).
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Dec 9, 2011 4:12 PM (in response to talwilkins)
    Re: Amp B silent in Dual amp mode
    I think the problem is that your patch setup is such that the Inputs are routed seperately to Path A and Path B because you have no FX before the split path. In this setup. Input1 is routed to Path A and Input 2 to Path B. If you are only using Input1 then you won't hear anything from Path B until/unless you place an FX before the path split.
    The Source Signal Input Routing is explained in the manual in the Inputs section. Have a look - it will explain things more clearly.
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Dec 14, 2011 11:56 AM (in response to talwilkins)
    Hey talwilkins,
    +1 to silverhead.
    Without the effects in front of the amps, you will need to make sure that input to is set to 'Same', that way the signal from your input source will be sent to both amp A and amp B. Without making this input source change, amp b will be looking to for input from another source, therefore amb B will be silent enless of course you did have something connected to this source.
    For assistance configuring your input source you can check out the POD HD500 advanced users guide at the link below:
    http://l6c.scdn.line6.net/data/l/0a06434dc7704ca4b3b26b924/application/pdf/POD%20HD500%20Advanced%20Guide%20(Rev%20B)%20-%20English.pdf
    We also have a video tutorial that illustrates how to configure input sources for your presets:
    http://line6.com/support/docs/DOC-2525
    Jan 27, 2010
    Dec 20, 2011 3:06 PM (in response to talwilkins)
    Hello. It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered. If it has been answered, please award points to whoever was helpful and/or answered the question.
    In the event your issue has not been resolved, I created a support ticket for you so we can continue to communicate. Please respond to the ticket. Thanks!!
    Q: What is a support ticket?
    A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link to the ticket when a Line 6 Support Representative responds to it. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support. Also, in your account, click My Account, then click Support Tickets to view the support ticket. Here’s a shortcut: http://line6.com/account/tickets/view/.
    Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host, and also that your email account is receiving messages at all.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
