Dec 11, 2011 8:05 AM
Variax 700 with graphtechs.Problem (again)
Like (0)
Hallo everyone, I recently upgrade the variax piezos with graphtecs, and all seemed good until...I started played dynamically..
The wounded strings (E,A,D) sounded loud, pretty loud even with a very soft picking, while the unwounded strings (G,B,E) didn't sound at all.
I used the workbench to adjust the volume, but even with settings of 10% for the wounded and 100% for the unwounded didn't solve the problem.
I reflash, but again, nothing.
When I installed the piezos, I cut the wires, separate them, put the silver on the pcb possitions that was the variax before, and the ground (blue), put them all together, and solder them together with the green one.
I have a variax 700 with tremolo.Any help / suggestion?
i grounded all my pickups to the bridge plate not a green wire.. try that.
Can you please specify me where exactly?Or about where?
what i would do is loosen the trem block mounting screws.. slip a piece of stripped wire between the block and the bridge plate.. retighten the screws. this will give you something to solder to. now youlll be grounding to the bridge plate like my 300 is. ive had no problems with mine. the other thing is check for a ground wire at the tremelo claw. if it has a ground wire you can attatch to that.. also check the pcb isnt touching anything like the trem block. theres supposed to be a double sided tape insulating and attatching the pcb. if its not and the pcb is touching anything .. you could be shorting the board..
seems to me that if 3 pickups are loud and 3 are mute... you may have a short or have done something wrong. also that one may have a ribbon cable . if so reseat both ends in the connector. when i did mine all volumes were equal. your the first one ive heard of who has had trouble with this so most likely you need to check over what you did..
Thank you very much for all your kind efforts!I will look at it tommorow and let you know!Thanks a lot ![]()
Just to clarify, that the 3 are not mute, are with very small sound.
amx, you are my hero!Thank you man, my baby is working better than ever !I am so happy,that when I hear it sounding normally I started cryin :') !God how much I love my variax!Thank you very much man!
