Dec 21, 2011 11:03 AM
LIne 6 M5 Model Select (button) stopped working
Like (0)
Was redoing and renaming some patches..no problem....then went to get to the Set Up menu ( Hold Tap and Press Model Select) no dice ... it went to tuner..several times,a sModel Select "press" function seems to have stopped working.
So I went to edit a patch and SAVE ( hold down Model Select) no dice.Model Select will rotate fine ...just not the "press down" function
Tried "rebooting" the unit by unplugging /re plugging in power supply...still no...
Am I missing something? or do these switches go bad... had this unit about 2 weeks...no problems
Fixed it....following advice on a similar thread.Pulled off knob and grabbed metal pot shaft w/pliers and lifted up. I could feel it move back into it's "seat. (like a dislocated finger going back in the socket)
Pressed down and it works.
