204 Views 5 Replies Latest reply: Oct 30, 2012 9:05 AM by JTSC777 RSS
ryanh92 Just Startin' 9 posts since
May 30, 2008
Dec 25, 2011 10:55 PM
Talkbox..
I have a talkbox i'm wanting to use. is it possible to run the setup entirely through the pedal or is it completely necessary to have an amp? if i can run everything through the pedal, could someone please explain how to do so? thanks alot.
  • arislaf Iknowathingortwo 426 posts since
    Sep 8, 2010
    Dec 26, 2011 1:56 AM (in response to ryanh92)
    Re: Talkbox..
    1st of all, you have better chances to get help if you will go to: support>technical support>support forums, and sellect your gear.
    2ndly, what pedal you have?
  • aaron__aardvark Just Startin' 1,269 posts since
    Jan 25, 2007
    Dec 26, 2011 5:28 PM (in response to ryanh92)
    Re: Talkbox..
    Are you using a Heil Talk Box, a Rocktron Banshee, or something different for a talk box?
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    Dec 27, 2011 6:53 AM (in response to ryanh92)
    Re: Talkbox..
    I would think that you still would need an amp. The talk box works by having the amp's power amp section drive the speaker horn in the talk box. The HD500 is really just a pre-amp.and cannot drive a speaker.
  • JTSC777 Just Startin' 63 posts since
    Jun 22, 2012
    Oct 30, 2012 9:05 AM (in response to ryanh92)
    Re: Talkbox..
    The Heil units are old technology and are passive. They must be powered by your amp or a seperate small amp to drive it. It is essentiaslly a mid range driver with no plastic horn on it. The tube goes into the hole the horn typically mounts on. Buy a Rocktron Banshee. Very easy to use. Built in preamp so you can vary the gain. Good Luck!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
