281 Views 7 Replies Latest reply: Jan 6, 2012 2:36 AM by SignaturePre RSS
SignaturePre Just Startin' 9 posts since
Oct 18, 2011
Dec 29, 2011 11:41 AM
HD PRO + 4 Expression Pedals?!
Hi Every Pod HD Users!
The only thing stoping me from calling the POD HD PRO a Fractal killer is if it is possible to run up to 4 Expression pedals as I`m using a Liquid Foot Pro that is offering conection of 4 independent expression pedals.
Anyone who know if Line6 is working on such add to the Firmware 1.4?
Best Regards
SignaturePre
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Dec 29, 2011 2:04 PM (in response to SignaturePre)
    Re: HD PRO + 4 Expression Pedals?!
    I doubt there would ever be any movement in that direction, as the most any Line 6 controller can support is two. It would require quite a bit of re-writing to add that in. While not technically impossible, I suppose, I just don't see it being something Line 6 would want to invest the time into changing. Really, who uses 4 expression pedals?
    • spikey Just Startin' 378 posts since
      Feb 1, 2007
      Dec 31, 2011 2:27 PM (in response to phil_m)
      who uses 4?
      Well, theres Volume, Wah, and that leaves two more. The ability to go gradually from clean to distorted I have used many times. The ability to go from a slow univibe to faster I have needed. The rotor speeds from the leslies to go faster or slower is a plus. Tremolo speeds? I would think that there are "many" uses for more than just two pedals. Who would use 4 expression pedals? I might... ; )
  • gunpointmetal Just Startin' 171 posts since
    Dec 27, 2010
    Dec 30, 2011 12:27 PM (in response to SignaturePre)
    Are you really using all four of those options at all times? I'd like to hear how that works.
      Feb 1, 2007
      Dec 31, 2011 2:32 PM (in response to gunpointmetal)
      No...,  you wouldnt use all 4 at all times gun. Thats why they are called options.... ; )
      But to never have these options available means you and I would NEVER use them. Money dictates everything of course, but that aside which is better- No options or many???
