Line 6 - Support
7478 Views 10 Replies Latest reply: Jun 5, 2010 5:59 AM by mko0 RSS
bobsywobsy Just Startin' 7 posts since
May 11, 2009
May 11, 2009 3:03 PM
Pod 2.0, conneting to computer
Hi
I'm trying to connect my pod 2.0 to my computer so i can download different tones/ effects.  I have bought what i think are the correct midi cables ( its a MIDI USB IN and OUT... im not very familer with any of this).  The cables connect into the pod easily and have put the MIDI IN cable and OUT in the correct slot in the pod.
I downloaded the Line 6 edit and Line 6 Monkey but have had problems getting it to recognise my Pod 2.0.  When I insert the USB into an open slot in my computer, the computer recognises the device (a balloon comes up saying its recognised device and ready to use).  BUT... on the line 6 edit when i try to configure i click "Refresh"... nothing happens, so i click add and select my Pod 2.0 and click "ok" and i get "no device" "Could not connect to pod 2.0, please check all MIDI and power connections and click 'refresh' in the tone locker" and i still cant get it to recognise.
On the MIDI cable i have the power LED light lit... but there are 2 other LED lights IN and OUT which arent lit.  Everything seems to be connected fine.
Any ideas? any advice would be great!
Thanks
Bobsywobsy
PS. Look at the attached pictures if it helps. Thanks
  • swedebass Iknowathingortwo 286 posts since
    Mar 2, 2009
    May 11, 2009 4:07 PM (in response to bobsywobsy)
    Re: Pod 2.0, conneting to computer
    try flipping the in and out cables
  • nadaroy Just Startin' 2 posts since
    Jul 26, 2006
    May 18, 2009 8:34 PM (in response to bobsywobsy)
    i have the same problemes..anyone have an idea?
  • warlok Just Startin' 8 posts since
    Oct 23, 2007
    Jun 9, 2009 11:19 PM (in response to bobsywobsy)
    Did any of you get this sorted out? I have the exact same problem. First I tried it with the adapter you have in your pic. Didn't even recognize anything. Now I have a Tascam US-122L interface and I'm having the same message you're getting. This is getting quite frustrating!!
  • LH62666NEW Just Startin' 2 posts since
    Nov 16, 2009
    Nov 16, 2009 10:56 AM (in response to bobsywobsy)
    I'm having the same issues.  Will the POD 2.0 work with MIDI cables that attach to a Soundblaster Live MP3+ 15 pin MIDI port?  I'm not able to get anything.  Have the cables OUT to the POD's IN and visa versa, have checked all the channels and ALL itself, rebooted the computer with the POD on and in MIDI mode, nothing works.  I just keep getting the same "Could not connect to the POD 2.0.  Please check...."" message.  Could this be a driver issue or am I plain out of luck with the older MIDI cabling?  My computer is an AMD64 running Windows XP Pro SP3.  Thanks.
    POST NOTE:
    It is detected by the latest Monkey software and has the 2.54 install and is connected via MIDI so I know it is communicating with computer but the Line 6 Edit software doesn't see it.
      Nov 16, 2009
      Nov 18, 2009 1:56 PM (in response to LH62666NEW)
      The issues I was having have been solved and so that there might be others who are having connectivity issues like mine and are connecting as I do, I am providing what worked for me.
      First off this is for those who are using traditional MIDI cabling that connects to a sound cards 15 pin D-shape MIDI port, particularly the Soundblaster PCI Live card.  Other cards may be similar.
      The first thing you are going to need is Java's runtime environment ver. 1.5.0_22.  This can be had by going to https://dct.sun.com/dct/forms/reg_us_0809_958_0.jsp and filling out the information needed to download it.  The ability to download it comes from a link that you receive by email (Sun does this with end of life softwares, dunno why).  Run the download.  The reasoning for this is that the latest version of Sun's JRE has issues that prevented my POD from being recognized by the MIDI port.  I found others saying that the older release worked and since it does, I'm passing it on.
      Secondly, you will need to have the latest version of Line 6 Edit which is currently ver. 3.02.  You can find that on the site easily enough if you don't already have it.  What I needed to do was uninstall it, then install the JRE above, then reinstall afterwords.
      Thirdly, after having connected your POD and turned it on, run Line 6 Edit and in the MIDI devices box, select add and select SB Live! MIDI port [EA00] for both in and out.  Do not bother with using the MIDI button of the POD but just have it on and connected.  Once done with this, click OK.  The program will cycle through fairly quickly and you should end up with the help screen up (this will always come up but you can uncheck it to prevent it) and you should be seeing the Tone Locker view of Line 6 Edit with your downloaded tones and templates folder view on the left and your list of amps on the right.  Now you can download all those amazing tones or create and save your own.  This program ROCKS!  I can now save my settings more easily than before and can precisely recall them with a few clicks.  Thanks Line 6!
      • Ronco46 Just Startin' 3 posts since
        Jun 22, 2009
        Jan 22, 2010 9:45 AM (in response to LH62666NEW)
        Hi!
        I've my POD 2.0 connected to a pc via a M-Audio Uno 1x1 (cable + adapter) and it works very nicely, i should say. Downloaded great tones and uploaded some fairely audible ones
        I also have a software called Guitar Pro 5 installed in the computer.
        I can write songs in Guitar Pro using a MIDI keeboard.
        I would like to do the same, using the POD... is it possible? can I play the guitar and get the notation written automatically in Guitar Pro? Because it is possible with the keeboard. Anything I shoul configure differently with the MIDI In/ Out configurations? Any advice?
        Thank you very much!
        Miguel
      • mko0 Just Startin' 1 posts since
        May 8, 2010
        Jun 5, 2010 5:59 AM (in response to LH62666NEW)
        • I´ve done every thing. I´ve downloaded java, line 6 edit, line 6 monkey and my pod is connected and i´ve downloaded all the tones i want.
        • But i´m having trouble syncing them on tone locker.
        • HELP!!!!!!!
