79 Views 2 Replies Latest reply: Jan 20, 2012 11:37 AM by Line6Perry RSS
markepstein Just Startin' 3 posts since
Jun 7, 2010
Jan 6, 2012 12:50 PM
Midi Memo export and import
It appears that once you export files, there is no way in iTunes to delete them.  So if you later import, you'll end up with a duplicate.  Is this working as designed?
Also, I tried to import MID files not created by MM, and the files were not imported.  It would seem that MM can not import files it did not create.  Why is this?  Doesn't midi=midi=midi?  Is there some fairly trivial editing I can do to my MID files to make them MM friendly?
Only sometimes does MM tell me it cannot import a file it did not create.  Other times, the file is deleted from the iTunes list, but not placed on the iDevice and no warning was given.  Is there some sequence I need to follow?
    • Line6Perry Line 6 Support 6,880 posts since
      Dec 26, 2007
      Jan 20, 2012 11:37 AM (in response to markepstein)
      Re: Midi Memo export and import
      Sorry for not responding sooner. Both of your points are correct, but unfortunately does not exist with the current build of MIDI Memo app.
      I've taken your thoughts and presented them internally to the development team. Sorry about the inconvenience. Hopefully these behavioral changes will be rolled out in a future release of the app.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
