Jan 10, 2012 12:46 AM
HD500 input setup for 2 guitars and piezo
Like (0)
I just updated to 1.4, so now the input default is global, which makes sense for most people, mainly because without global we would have to reassign every preset input setup to "guitarvariax" to keep from overloading the input, But what I want to set up is guitar in one input and lap steel in the other input, but not all the time, at a lot of gigs I don't have room to set up the lap steel stand and only play standard guitar, which needs "guitarvariax" to keep from overloading input. Also I want the option of running my electric guitar's piezo pickup separately into the other input, which obviously would require an extra A/B box. I am running a KoT overdrive in the FX loop so I could not come in the return jack with the piezo. Anybody got any suggestions on the best way to configure?
Hi
In your situation I think you simply need to set up your inputs on a per preset basis as Global won't cover every eventuality unfortunately.
Nick
+1 on Nick. The configuration to change from 'Global' to 'Preset' is found in 'System Settings'
Nick_Mattocks's answer above is correct. I have marked the answer that is correct for your question, please help out the community by marking other suggestions that were helpful to you as "Helpful Answer".
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
