418 Views 8 Replies Latest reply: Jan 16, 2012 5:28 AM by laplayantonio RSS
LiJnox Just Startin' 5 posts since
Nov 5, 2011
Jan 13, 2012 1:20 PM
USB Firmware
Ich habe meinen Pod angeschlossen und in Line 6 Monkey alles installiert, außer die USB Firmware, die geht nicht. Ich drücke auf Updaten, dann kommt dieses Fenster, dass ich die Bedingungen akzeptiere, und dann drück ich auf akzeptieren und ok, und dann kommt: Could not establish a connection to the Pod HD 300. Please Check your USB Cable Connections. If the device is plugged in, try disconnecting then reconnecting the USB Cable.
Was mache ich falsch? Ich habe jetzt schon 20 mal das Kabel rein und rausgesteckt!
Ich wäre sehr sehr sehr dankbar wenn mir jemand helfen würde.
Gruß
LiJnox
  • birro Iknowathingortwo 172 posts since
    Jun 27, 2007
    Jan 13, 2012 8:00 PM (in response to LiJnox)
    Re: USB Firmware
    Had to use a translator... I can't speak german.
    I hope you can read english.
    Lots of people has problems installing the USB firmware. Which version of Windows (or Mac) are you using?
    Please follow these instructions carefully:
    1) Uninstall ALL drivers from Line 6 from your computer. Do it with the USB cable unplugged from your HD300
    2) Turn off your computer (to clean up RAM memory, very important if it's Windows XP), then turn it on again
    3) Download the Drivers:http://line6.com/software/
    4) Install the drivers (please, keep the USB unplugged!!! Don't plug it!)
    5) Almost at the end of the installation, the software will ask you to plug it. IMPORTANT: at the END of the installation
    6) Read carefully: Turn OFF (power off) your POD. Plug the cable on a different USB port on your computer (don't use the USB you tried 20 times earlier. Use another one for Microsoft Windows litterally install a new driver). Plug it with the POD Turned Off.
    Note: It's dumb but a usb driver installed for a USB port #1, won't work on USB #2 for example. So if you have removed the USB drivers, even if Windows hasn't deleted the driver for any reason, using a different USB port may help you.
    7) Check: Computer USB plugged? POD USB plugged? Turn the POD On
    8) Wait to check if the unit will be recognized by your computer (Windows 7 will let you know in about 10-30 seconds with a message nearby your clock)
    Post your results for us to know what happened.
    If something fails agian, please tell us which OS (operational system) you're using.
    Gruß
  • laplayantonio Guru 2,435 posts since
    Sep 26, 2006
    Jan 16, 2012 5:28 AM (in response to LiJnox)
    Re: USB Firmware
    hello
    the answer(s) above is correct: If all of your questions have been answered please be sure to mark as 'Helpful' or 'Correct Answer' to community members who respond with helpful or correct answers, to close out the thread as “answered” if your situation has been resolved. Thanks!
    FYI, Support auf Deutsch findet in http://de.line6.com/company/contact/27/ statt
    line6antonio
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
