Jan 14, 2012 12:19 PM
How can i let my DT 25 work and switch through midi with a voodoolab groundcontrol?
Like (0)
Gr. Hans
Just posted same question for general MIDI. I had no response from the support of Line6.
Do you meanwhile have a solution?
Ciao, F12
From evaluating the Ground Control's manual I believe you will have to use the Instant Access feature in the Ground Control to assign the Proper MIDI CC values to footswitches 1-8 on the ground control. The MIDI Implementation guide for the DT50 is listed in your Pilot's Guide on the last page.
I would suggest you contact Voodoo Lab about setting up the pedal:
http://www.voodoolab.com/contact.htm
Or reffer to the manual for your Ground Control:
http://www.voodoolab.com/manuals/gc_origv2manual.pdf
Thanks,
David
Line 6 Customer Support
Father12,
The MIDI Implementation for the DT25 has not yet been documented on our site, so at this time, controlling the amp via MIDI is not fully supported. We will be relelasing this data when it becomes available.
Regards,
Line6Hugo
Hi. Do you already have the fully MIDI implementation to the DT25?
I am trying to change the Drive Knob via MIDI CC, but...
even assigning the CC#13 and some values between 0-127 I can not be able to sucess.
Do you have some clue about this fact?!
Thank you
Cheers from Brasil
