626 Views 8 Replies Latest reply: Aug 16, 2012 5:15 AM by peter77555 RSS
jimsreynolds Power User 2,227 posts since
Jun 27, 43450
Jan 15, 2012 5:40 AM
Safe mode ... what button for what device for what firmware etc?
Experts & Line6NameGoesHere folks
I have read several different ways of accessing POD HD 'Safe Mode' on the forum.   These include:
  • Power up + Directional Keypad 'Down' (The one I have been recommending)
  • Power up + Directional Keypad 'Right'
  • Power up + Directional Keypad 'Left'   (thought I also understand that this is the Global Settings Reset)
Now I am pretty sure that I have seen end users report back success with each of these button combinations but have not really been clear on why some seem to work one way afor some people and some for others.   I can only guess it relates to one or all of firmware version/POD HD device/specific functionality.
Is there anyone who has the definitive 'What key combination does what on what' list?  I appreciate there are some functions that casual users should not mess with but the advice on the forum is already very fragmented now and that is risky.
Can anyone shine a light?
    Mar 26, 2007
    Hi Jim
    For the POD HD500, POD HD (bean) and POD HD Pro
    • Power Up and Nav Pad Right = TEST mode and Safe Mode - used to test button and expression pedal functionality as well as to recalibrate the expression pedal.  You can avoid some flash memory update issues by updating in this mode
    • Power Up and Nav Pad Down = direct access to Flash Memory update mode - good if you need to update your flash memory and cannot access update mode in any other way
    • Power Up and Nav Pad Left = Global Parameters Reset - can get you out of a start-reboot loop if the patch you last used is corrupted because it defaults back to Set List 1 Best of HD 1A Son of Plexi - if you use this with the POD HD500 you will need to recalibrate the expression pedal and rename Set Lists 5-8 back to whatever they were named prior to resetting the Global Parameters
    The POD HD300 and POD HD400 work in a different way, and not having access to one I can't be sure what the recipe is for these two units
    Nick
      • silverhead Expert Line 6 User 9,592 posts since
        Apr 1, 2009
        Pod HD300/400:
        - power ON while holding down A Footswitch = Factory Reset. All factory presets are restored; no firmware update.
        - power ON while holding down D Footswitch = Initiate Pedal Calibration procedure.
        Holding down any of the nav keys does not have any effect at startup.There is no Safe Mode startup that I can see offhand on the HD400. I will investigate this further and report back if I find it. It seems to me that there should be a way to test switch/button operations but I can't find it in the documentation nor on the device itself - at least not yet.
        EDIT: Found it. On the HD400 (I don't have the HD300) hold down the TAP footswitch while powering on to enter TEST mode. All switch/button operations can be tested.
  • Cleuvenot Just Startin' 21 posts since
    Feb 27, 2011
    Pod HD 300
    Powering on while pressing the TAP switch initiates a TEST mode which seems quite interesting: various test informations are available on the pod screen, rotating the PRESET button.
    I just discoverd that while trying to restore the footswitch leds which did not work anymore.
    Finally, a factory reset did it.
    Anyway, this test mode could interest some of you.
  • peter77555 Just Startin' 1 posts since
    May 20, 2011
    I have dsp boot failure... I have tried reinstalling all the software, i have tried doing factory reset.. and it still doesnt work, i have a gig tomorrow and need it to work so i can restore all my settings.. PLLLEEEAAASSSSEEE HELLPPP!!!
Bookmarked By (2)
