Jan 15, 2012 10:14 PM
DL4 problem - Static/Hiss w/ effect engaged
Like (0)
I'm having an issue with my Line 6 DL4 Delay/Loop Pedal. The bypass output sounds great - clear & clean. But, when the effect is engaged, the sound is accompanied by a loud hiss/static sound.
My rig is a Martin X-Series Acoustic/Electric Guitar, Monster Guitar Cables, Bose L1 Compact, all powered by a Furman M-8L Power Conditioner. I have also tried other cables and guitars with the same result.
I have uploaded a video of my problem to YouTube Here: http://youtu.be/p8hzwUAthJk
I would suggest to try a factory reset on the DL4 by:
Holding the A and D footswitches and power up. The power is turned on and off on the DL4 by inserting a plug into the left mono input jack. The DL4 will need to have either battery or power supply power in order for it to be reset. If you did it correcltly you will see the Red LED lights of the DL4 light up from side to side. Try it again to see if the loop sound quality changes at all. One other thing to try it turning up the far right most knob on the DL4 that is labeled mix. This should turn up the loop volume playback, just in case the noise is related to the output setting or pot.
If you are still having poor sound quality with the DL4, you will need to have it assess by a authorized Line 6 Service Center. To find one in your area, follow the link below:
I have marked the answer that is correct for your question.
If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
http://line6.com/support/community/support/
For more information about using the Online Technical Support System please review our FAQ at the link below:
http://line6.com/support/docs/DOC-1451
Thanks!
