416 Views 3 Replies Latest reply: Jan 20, 2012 7:32 PM by rgrimes RSS
rgrimes Just Startin' 2 posts since
Jan 18, 2012
Jan 18, 2012 7:32 PM
Echo Park power supply issues
I have the Echo Park pedal and would like to use a power supply with it.  I cannot find one that came with the pedal (if one did actually come with the pedal), so I purchased the DC - 1G that was recommended from the Line 6 website.  I plug it in and nothing happens.  Am I doing something wrong?  Did I get the wrong power supply?  The pedal works with a battery, so I know it works.  It has hardly been used, so it should be in good shape.  Any suggestions?
Richard
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Jan 19, 2012 3:34 PM (in response to rgrimes)
    Re: Echo Park power supply issues
    No, the DC-1g is the correct power supply. Did you connect a 1/4" instrument cable into the MONO/L input jack? Also, sometimes you might want to remove the 2 hex bolts on the side of the dock and then de-press the circular release tab. This allows you to remove the effect module and inspect the contact pins. Clean them and re-seat the module back into the dock and re-test.
  • BigChas52 Expert Line 6 User 2,315 posts since
    Mar 12, 2007
    +1 to L6Perry.  Do you have the instrument cable plugged in?
    BTW . . . The power supplies do noy come standard with the pedal (so you didn't lose it).  If the battery is working, and the power supply is not, I'm wondering if you got a bad power supply.  Can you take it to the store where you bought it and try a different one?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
