71 Views 5 Replies Latest reply: Feb 21, 2012 4:51 PM by Line6david RSS
jamaddiss Just Startin' 3 posts since
Feb 14, 2009
Jan 24, 2012 6:22 PM
Gearbox start up noise
When I start my Gearbox software, it is making a lot of noise, louder than the guitar signal. If I close out the software, unplug the usb cable for a minute and start it up again, that will usually stop the problem, although I may have to restart it a few times. Any ideas what might be causing this?
  • Line6Tony System Admin 1,820 posts since
    Jan 16, 2007
    Jan 26, 2012 1:49 PM (in response to jamaddiss)
    Re: Gearbox start up noise
    Let's try to narrow down where the problem is.
    1. Is this happening on multiple computers? If not, the original computer may have a configuration issue. Please see our USB Audio troubleshooting FAQ: http://line6.com/support/docs/DOC-4282. If it is happening on multiple computers, then you'd have to look at your Line 6 hardware as the problem.
    2. Does your Line 6 device have any problem with any other software such as a media player or audio from the internet? You may want to uninstall then reinstall the latest drivers for it, as well as Gearbox either way.
    3. Make sure to connect to all USB ports (no hubs) on the computer and remove all non-essential USB devices during testing.
    4. Make sure to remove other audio interface drivers during testing.
  • Line6david Line 6 Support 5,236 posts since
    Jan 27, 2010
    Feb 21, 2012 4:51 PM (in response to jamaddiss)
    Gearbox will work on any computer that you have you UX2 plugged into as long as the drivers are installed and up to date. It is Windows 7 Compatible.
    Thanks,
    David
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
