531 Views 12 Replies Latest reply: Mar 14, 2012 3:17 PM by Chris_Wohlfahrt RSS
Chris_Wohlfahrt Just Startin' 20 posts since
Mar 24, 2007
Feb 9, 2012 7:56 AM
JTV 69 Body Ridges
     My Black JTV 69 arrived in September last year with perfectly flat finish on the top, but about mid-January I noticed two distinct ridges in the finish that look like movement of the laminated body pieces.  The sales rep at Long@McQuade had a look and thinks "its a bit dry" due to winter weather.    I'm not sure he's correct....my house is newer construction with humidity controlling ventilation and A/C heating.  The Variax 300, 30yr old Vantage and two acoustics that hang in the same spot have never had these issues.
     My questions:
is this kind of thing covered by the "wood" section of the warranty.   (it had better be)
can I expect it to settle back with age,  (probably not)
or is this a symptom of a structural fault.   (???? you be the judge)
     I wasn't able to get a photo that shows it clearly, but to the eye its quite obvious.
Anyone else out there notice the same thing?
Update:  I'm going to take guitar back to the store today for return or replacement...here is a pic of the electronics cover plate on the back which is bowed up due to the deformation of the body,
....and the lines in the finish are now apparent on the back of the body right up to the neck mount holes.   Yuck.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Feb 9, 2012 11:24 AM (in response to Chris_Wohlfahrt)
    Re: JTV 69 Body Ridges
    Hi Chris... looking at those two pictures (in particular the lower one), there's definitely a problem with that guitar. In Canada, please get your instrument back to the Long & McQuade that you bought it from and they will be able to help with an exchange or whatever you communicate to them. Sorry about the inconvenience.
    Jan 27, 2010
    Mar 5, 2012 11:24 AM (in response to Chris_Wohlfahrt)
    This is strange... I haven't seen any instruments blemished this bad out of the box... Here is the number for the Canadian Distributor:
    SF Marketing, Inc.
       Servicing: Electronics, Guitars
    325 Boul. Bouchard
    Dorval, Quebec
    H9S 1A9
    514-780-2070 (phone)
    stevec@sfm.ca
    Please get in contact with them and they should be able to help. Can you post pics of the second guitar?
    Thanks,
    David
    Line 6 Customer Support
    Jan 27, 2010
    Mar 6, 2012 11:19 AM (in response to Chris_Wohlfahrt)
    I'm sure that SF Marketing will provide a guitar that does not have these cosmetic issues. Sorry for the shape of the instruments. I feel like you are in good hands with Long&McQuade and SF Marketing and the issue should be resolved shortly. I will keep an eye out for issues like this in the future. I am opening a ticket with you. Please respond directly and let me know the condition of the next replacement.
    I created a support ticket for you so we can resolve this issue. Please respond to the ticket. Thanks.
    Q: What is a support ticket?
    A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
    Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host.
    http://line6.com/account/tickets/view/
    Thanks,
    David
  • jdolby Just Startin' 80 posts since
    Jan 24, 2007
    Mar 13, 2012 11:35 AM (in response to Chris_Wohlfahrt)
    This is very interesting.  My Black JTV-69, which was purchased in December 2011 has these issues now.  I did not notice these lines and grooves in the finish when I received the guitar.  Believe me, I inspected the guitar closely when I got it.  Well, after not playing it for about a month I have discovered lines and grooves in the paint finish that run along the length of the body - both front and back.  The electronics cover on the back is also bowing upwards.
    This is unacceptible for the price of these guitars.  I am officially requesting a service ticket.  Btw, I purchased mine at Long & McQuade, Waterloo.  Serial# W11080164
        Jan 24, 2007
        Mar 14, 2012 2:32 PM (in response to Chris_Wohlfahrt)
        Chris,
        Yes I did receive the correct tremolo arm with mine.  It did take me a while to notice the threads and that it screws in, though. :-)
        I have had no issues with the guitar other than some volume issues early on.  I adjusted the string volume and that fixed it for me.  I'ts definitely louder than my Variax 500 and my other guitars.
        I would love to trade in just the body because the neck is perfect on the one I have and I'm afraid of getting a less than perfect replacement.
        Are my ridges as bad or worse than the ones you had?
        JD
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
