Feb 6, 2012 5:22 PM
gx want work on windows 7 64 bit
Like (0)
I would suggest that you use the Line 6 Uninstaller located at the location below to remove your currently installed Line 6 drivers:
Windows 7/Vista - C:\Program Files(x86)\Line6\Tools - Line6Uninstaller
Make sure to disconnect any of your Line 6 USB devices prior to starting the uninstaller. Make sure to only check the boxes at the bottom of the list that are related to the Line 6 drivers, and proceed to uninstall them. Once they are removed, restart the computer. Upon restart download the latest Line 6 Window Drivers from the link below:
Windows Drivers 4.2.5.1:
http://line6.com/software/readeula.html?rid=4399
Make sure not to connect your Line 6 USB device until prompted to so at the end of the installation process. After connecting it, make sure and look towards the Windows system clock for a notification that Windows has detected your device and has successfully installed the drivers before moving forward. If you do not receive this notification message, make sure to try reconnecting the Line 6 hardware to each available USB port until you have exhausted all available USB ports.
