107 Views 5 Replies Latest reply: Feb 7, 2012 11:06 AM by AndyfromFL RSS
AndyfromFL Just Startin' 5 posts since
May 22, 2007
Feb 6, 2012 7:08 PM
High e progressive volume cutout until bend
Only when I have any model engaged, the high e, starting at the third fret and getting progressively worse, is quieter than the other strings, until I bend it about half a step and then the volume jumps (not gradually) and becomes as loud as the other strings. When I release the bend, the volume nearly shuts off at the same point it jumped up, but comes back to its original level when I release the bend. The high E string isn't touching any hardware, and I don't have this problem at all when I don't have a model engaged. I've tried plugging through a POD HD500 through the VDI and directly into an amp through the 1/4 jack and the problem persists.
The attached file is through a model, where you'll hear the problem, then without a model, where you won't.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
