458 Views 10 Replies Latest reply: Mar 5, 2012 7:26 AM by lubbertvg RSS
THORNSZ Just Startin' 31 posts since
Oct 17, 2011
Feb 8, 2012 8:24 PM
Mixing headphones
Can anybody suggest some headphones affordable good and accurate enough to mix some POD HD TONES?  as of now i'm kinda in a struggle of the accuracy of mixing the tones... i usually mix my tones on a behringer active PA. It does sound good but when i record them some times the treble or mid or bass sounds a bit more than the actual thing that i mixed with the PA. It sounds kinda scrachy...
  • Iknowathingortwo 1,667 posts since
    Jul 17, 2007
    Feb 8, 2012 9:26 PM (in response to THORNSZ)
    Re: Mixing headphones
    Personally I love my AKG K414 & K250 but I'm not sure these are what you'd call "budget conscience" headphones.
    I've even had a pair of KOSS headphones that were open air but were very comfortable and I thought they were extremely accurate for being much less expensive than what I use now.
    If possible, I think it best to bring music that you KNOW sounds a certain way you like and then plug the headphones into your .mp3 player or the stores without any added EQ.  Whichever ones sound the best to the music you like - those are the best choice for you.
    This is the only non-subjective way I could answer this.  I hope it helps.
    Take care,
    Neal
  • Dshow Just Startin' 38 posts since
    Feb 18, 2007
    Feb 9, 2012 12:20 PM (in response to THORNSZ)
    I'm using Sennheiser HD280 Silver Headphones. In my opinion they are very good headphones for the POD HD.
    Not too cheap though.
    http://www.sennheiser.com/sennheiser/home_en.nsf/root/professional_headphones-headsets_headphones_005327
  • chaosbringer Just Startin' 85 posts since
    Jan 29, 2008
    Feb 10, 2012 4:27 AM (in response to THORNSZ)
    ultrasone pro 750...not the cheapest but well worth the money
  • markcockerill Just Startin' 246 posts since
    Dec 7, 2007
    Feb 10, 2012 4:44 AM (in response to THORNSZ)
    I have a slightly different approach. I use Bose headphones but rather than monitor the HD500 directly, I have the HD500 output to 2 channels on my analogue mixing desk and plug the headphones in there. What I hear from the desk is precisely what gets recorded. The added benefit to this method is that the patches I create on the HD will need very little tweaking in my live environment as I use studio/direct output exclusively.
    I think I read it somewhere else on the forum that there is something not quite right about the headphone output on the HD500 so I don't use it. The Bose headphones as well as my older Sony cans bear testiment to that.
    In conclusion, if you mix on the HD500 with headphones then I suppose you really must use that socket to record as it ain't the same as what comes out of the quarter inch jacks and xlrs.
  • lubbertvg Just Startin' 7 posts since
    Nov 11, 2006
    Mar 5, 2012 7:26 AM (in response to THORNSZ)
    Beyer Dynamic DT 990 pro !!
