1109 Views 43 Replies Latest reply: Feb 18, 2012 3:08 PM by meambobbo RSS
Ax3M4n Just Startin' 127 posts since
Aug 22, 2011
Feb 17, 2012 2:42 AM
Line 6 - Please confirm Input Signal routing
this seems to be a recurring issue everytime something doesn't seem to work properly, and unfortunately the solutions contradict each other - they are mutually exclusive.
Does this represent the TRUE signal path in a POD HD (regardless of Input settings):-
Input 1  --> Mono Signal Chain to Mixer Input Left/A --> Mixer Output Channel A @ Left Stereo Pan Setting
Input 2  --> Mono Signal Chain to Mixer Input Right/B --> Mixer Output Channel B @ Right Stereo Pan Setting
So if both Mixer channels are centered you get a stereo output albeit centred in the stereo spread. You only get mono if you put a true mono FX or AMP after the mixer?
So what is the A/B splitter (Y Splitter) box for? It seems that it doesn't actually do anything?
To summarise previous "detailed" enquiries I have been told to:-
1) Set Input 1 - Guitar ;  Input 2 - Mic Trim pot down  - to avoid going in "too hot" to the amps and give me more headroom.
2) Set Input 1 - Guitar ; Input 2 - Variax - to provide a decent output level for USB recrding and provide more amp headroom as above.
3) Set Input 1 - Guitar ; Input 2 - Same - To provide more USB Output volume, more "tonal body" - but this then described as wrong for amp and clipping problems.
4) Set Input 1 - Guitar ; Input 2 - Same - so that there is actually a signal in Channel B. But f channel B is just for ambient FX - then overdriving AMP issue still exists in channel A (as per item 1).
In explaining signal routing, please can you also explain the logic behind it, because my mind still works in Guitar Mono outputs, mono cables and being able to only play one guitar at a time.
Your help is much appreciated.
Thanks,
Ax3M4n
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Feb 17, 2012 2:59 AM (in response to Ax3M4n)
    Re: Line 6 - Please confirm Input Signal routing
    Whether you hear one input on both channels or both inputs on separate channels is all about how you  setup your patch.
    From the HD500 Manual, section 2.6  (for the 1.4x firmware release) ...
    2.6 About Source Input Signal Routing:
    It is important to note how POD HD500 actually routes Source Inputs 1 and 2 through Amp & FX Blocks that are positioned “Pre” position. The following behaviors apply:
    • In a configuration with no Amp or FX Blocks in Pre, Input 1 is fed only to Path A and Input 2 only to Path B. Therefore, this is the best configuration if you want to retain discrete Input Sources into Paths A & B.
    • Placing an Amp Block or an active mono FX Model in Pre results in a “mix-down” of Input Sources 1 & 2, feeding the same, combined signal into each Path A & B.
    • Placing a Stereo FX Model in Pre results in the left channel FX output being fed to Path A and its right output to Path B.*
    • The Mixer Block’s Volume and Pan options provide independent control for Path A & B outputs before they are fed through any Blocks positioned “Post” the Mixer.
    • By setting Input 2 to “Same,” this effectively routes your Input Source to both stereo Paths A & B (which is how you can feed one guitar input into two Amp Models and/or parallel FX, for example).
    * Please also see “Model Types and Mono/Stereo Signal Routing” on page 3•6 for more about how mono and stereo FX affect your signal chain.
    3.6 Model Types and Mono/Stereo Signal Routing
    It is important to note that some Models (all EQs, Wahs & Volume, and some Modulations, Filters, Pitches and Delays, as well as the FX Loop) preserve a stereo output within the signal chain, while others (all Dynamics, Distortions, all Amps & Preamps, and other various Models) are mono FX and do not. The POD HD500 Inputs 1 & 2 are fed into the signal chain as stereo (see “Page 3, Setup: Input Options” on page 2•4). Therefore, wherever a mono FX or Amp Model is inserted, the Left & Right channels of this stereo signal is “mono-ized” and heard as a two-channel mono signal at the Model’s output. To follow are a few examples:
    There are some good illustrated example of this in the advanced manual and I suggest that you download this from this site.  Also check out the diagram posted by Deandinosaur earlier in this thread here  http://line6.com/support/message/328666#328666
        Jun 27, 43450
        Feb 17, 2012 3:40 AM (in response to Ax3M4n)
        I am a bit confused .... what is this 'A/B Splitter' of which you speak?
        I have the HD500 and have been through the full set of effects and cannot see that ... or something that matches this description.  Are you talking about the point where the signal path splits to go through the two chains, as opposed to an effect block?
        If so:  the chances are that the Q-Filter is a Stereo effect and will therefore channel Guitar Left and Mic Right through the remainder of the chain.  You could try putting another, Mono, effect directly after the Q-Filter and see what that does for you.
        Make sense?
      • meambobbo Iknowathingortwo 1,702 posts since
        Dec 13, 2007
        Feb 17, 2012 7:44 AM (in response to Ax3M4n)
        I don't think anyone directly answered your question about your patch, but it looks like the Q-Filter must be a stereo effect if you're not getting any signal in path B.  IE
                   |-Q-Filter-|   /---- Path A
        Input 1 ------------------
        Input 2 ------------------
                   |__________|   \---- Path B
        The Q-Filter is processing each half of the incoming stereo signal individually, where input 1 is the left side and input 2 is the right side. So if Input 2 is a null input, Path B isn't getting any signal.  Compare this to:
                   |-Mono FX--|   /---- Path A
        Input 1 ----\________/----
        Input 2 ----/        \----
        Here the stereo input signal is merged into a mono signal inside the effect, processed as a mono signal and split into two equal signals fed into Path A and Path B.
        It would be quite helpful if there was some indication of whether an effect was processing as stereo or mono in Edit or the unit's edit screen.  I guess you just have to experiment, or look at external guides for now.
          Dec 13, 2007
          Feb 17, 2012 11:10 AM (in response to meambobbo)
          Just to add, what Phil is saying below is correct - Paths A and B are also stereo signals, so the diagram should look more like this:
                                     ___________     _ Path A Left
                                    | Stereo FX |  _/
          Input 1 (pre-split Left)__|___proc____|_/ \_ Path A Right
          Input 2 (pre-split Right)_|___proc____|_   _ Path B Left
                                    |___________| \_/
                                                    \_ Path B Right
          Pre-split Left (input 1) is processed without mixdown by Stereo FX and feeds into Path A where  it is split into a stereo signal with equal signal in left and right.
          Pre-split Right (input 2) is processed without mixdown by Stereo FX and feeds into Path B where it is split into a stereo signal with equal signal in left and right.
                                    |  Mono FX  |  _/
          Input 1 (pre-split Left)__|           |_/ \_ Path A Right
                                    |\__proc___/|
          Input 2 (pre-split Right)_|/         \|_   _ Path B Left
                                    |___________| \_/
                                                    \_ Path B Right
          Pre-split Left and Right (input 1 and 2) are mixed down to mono and processed by a Mono FX, then split back into a stereo signal with equal left and right signals.  The left signal is fed to Path A, right to Path B, where they are again split into equal left and right signals.
            Dec 13, 2007
            Feb 17, 2012 4:24 PM (in response to meambobbo)
                                      |  Mono FX  |  _/
                                      |\__proc___/|
                                      |___________| \_/
                                                      \_ Path B Right
                                      | Stereo FX |  _/
                                      |___________| \_/
                                                      \_ Path B Right
                      ___________    ___________    _ Path A Left
                     |  Mono FX  |  | Stereo FX | _/
            Input 1 _|           |__|___proc____|/ \_ Path A Right
                     |\__proc___/|  |           |
            Input 2 _|/         \|__|___proc____|   _ Path B Left
                     |___________|  |___________|\_/
                                                   \_ Path B Right
                     | Stereo FX | |  Mono FX  |  _/
            Input 1 _|___proc____|_|           |_/ \_ Path A Right
                     |           | |\__proc___/|
            Input 2 _|___proc____|_|/         \|_   _ Path B Left
                     |___________| |___________| \_/
                                                   \_ Path B Right
                             _________________
            Path A Left  ___|     Mixer       |
                            |\_pan/level______|_Left
            Path A Right ___|/          \  /  |
            Path B Left  ___|            /\   |
                            |\_pan/level/__\__|_Right
            Path B Right ___|/                |
                            |_________________|
                             _________________
                            |     Mixer       |
            Path A Left  ___|_level_panL___   |
                            |              \__|_Left
            Path A Right ___|_level_panR_  /  |
            Path B Left  ___|_level_panL_/\   |
                            |              \__|_Right
            Path B Right ___|_level_panR___/  |
                            |_________________|
            panL = 100-pan right for channel.   so if the channel is panned 30% right, then panL = 70% of its original volume.
      Jun 27, 43450
      Feb 17, 2012 4:14 AM (in response to Ax3M4n)
      OK, yeah, so as I say: the trick is to have a Mono effect in the 'O' position on your diagram.  That will sum/average the two inputs before sending the combined signal into both channels.
                     I-------
                     I
      ----------O
                     I
                     I____
      Trying to think of what effect would be suitable though.  The neutral ones all seem to be stereo.
        Jun 27, 43450
        Feb 17, 2012 4:26 AM (in response to jimsreynolds)
        ... and through the magic of search, I got lucky with http://line6.com/support/docs/DOC-2099 courtesy of Fester2000 - the person that previously brought us DSP usage percentages by effect and amp!
        Looking down the list:  all of the distortions and Dynamic effects are mono but I think will effect your tone ... unless you want that.  The EQs are all stereo and therefore out as are reverbs and wahs.   Delays vary but all the (desireable) dry mix versions are stereo. Pitch effects are mono - but very resource greedy.
        The best bet may be to select one of the modulation or delay effects with a mix parameter and set it to 100%.  You MAY be able to use a Vol/Pan control centred and not connected to the Expression pedal.
          • silverhead Expert Line 6 User 9,592 posts since
            Apr 1, 2009
            Feb 17, 2012 6:22 AM (in response to Ax3M4n)
            I think your conceptual model of an A/B path splitter in the HD device is what's causing the confusion. The A/B paths in the HD device are not 'split' by an FX placement such as your Q-filter. The A/B paths are completely independent from the inputs - both inputs are seperate at the outset, and do not need to be 'split'. In fact, your Q-filter, being a mono FX, acts as a signal merger, not splitter. It takes two independent input signals and merges them into a single mono signal, which is then sent down two different and independent paths.
            By not placing any FX before the visual path split you are simply allowing the two independent inputs to be processed sperately, without being merged. You are not splitting them - you are just not merging them. I think the signal flow diagrams would actually be more accurate if they looked like this:
            Using mono-FX before Dual-Path processing (note I don't say 'before path split'):
            Input 1 ------                   Inputs1+2-----> Path A processing
                               mono-FX (merges inputs)
            Input 2-------                  Inputs1+2-----> Path B processing
            No FX before Dual-Path processing
            Input 1 -------> Path A processing
            Input 2--------> Path B processing
            The signal flow display on the HD device LCD would, imho, be more accurate if there were no vertical bar at all in the case where there is no FX before the 'split', as in the diagram above.
            A final note: if you are not using a dual-amp patch, the signal flow looks like this:
            Input1+2 ---> single path processing
            • chimp_spanner Just Startin' 336 posts since
              Nov 7, 2008
              Feb 17, 2012 6:43 AM (in response to silverhead)
              Thanks for the diagrams guys. This actually clears up how the routing works, although I can't imagine too many scenarios where I would want to merge the inputs and then process them separately again. Seems the easiest way to avoid confusion is to have it set up like Phil's screenshot from the getgo, and then you know for sure what's going on in your patch.
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Feb 17, 2012 6:23 AM (in response to Ax3M4n)
    To add a little addendum to what's already been said, I think the way to envision the A/B paths is to remember that each one is a stereo path. The A/B splitter, as you're calling it, doesn't separate into left and right, it's really more like a Y-splitter than an A/B box. So you have, potentially, a stereo signal being split into two separate stereo signals. When these stereo signals hit the mixer, they can be combined into one stereo output signal if the pan controls are left centered (or not hard panned), or you can hard pan them and then be left with a stereo signal that gives the left output of Tone A and the right output of Tone B. I won't say it's not complicated. It is, but it also gives you a lot of flexibility and options as to how you route things. It really opens up all sorts of possibilities.
    If you want a true A/B split, it can be done if you set up the patch like the attached. But, to your point, there's nothing really like an actual A/B/Y box in the HD500's arsenal of effects.
      Apr 1, 2009
      Feb 17, 2012 6:27 AM (in response to phil_m)
      .... and using phil_m's diagram above, I think it would be more accurate if the left side of the signal flow image did not show the portion to the left of and including the vertical line. It should just show the two horizontal lines indicating Input 1 and Input 2 completely seperate from the outset.
    • MartinDorr Just Startin' 98 posts since
      Nov 3, 2011
      Feb 17, 2012 9:52 AM (in response to phil_m)
      Your comment that each A and B path are (or can be) stereo raised my curiosity before. Honestly, I had my doubts but when I went back to the Advanced Guide I found a few references that support this view:
      • pg 2-4, 2nd bullet:
      • pg 3-6, last bullet:
        The FX Loop is capable of stereo, just like any stereo-output FX Model, provided that you utilize a stereo cabling configuration from the SEND jack, through your pedals/rack devices, and back into the RETURN jacks.
      • pg 3-7, first bullet:
        The above rules also apply within each of the parallel Paths A and B, since these are each stereo signal paths as well. The Mixer Block offers Pan controls to independently adjust the stereo balance of each of these Paths before they are fed into the first “Post” FX (or Amp Block, if the Amp is placed here), immediately following the Mixer.
      The fact that both path A and B can be stereo is probably not often useful for electric guitar applications because at some point you likely go through an amp or a mono effect before recombining the A and B signals with the mixer. But if an A/B path is used to process material from a singer, an accoustic guitar, or a keyboard (something you probably do not want to send through a guitar amp), the stereo capability of the A/B paths could be quite useful.
        Jan 25, 2007
        Feb 17, 2012 10:06 AM (in response to MartinDorr)
        Yep, it's not a view - it's a fact...
        It's easy to prove it to yourself if you want. Just set up a dual tone and put a true stereo effect (stereo delay with a different delay time on either side is a good one to use) after one of the amp blocks. Mute the other path completely in the mixer block. With the pan control in the center position you'll hear the stereo separation from the stereo effect. If you pan hard right or left, you'll only hear the respective side of the delay and not the other.
        The thing that is weird is that even though you have the potential of having a pair of stereo signals coming from the mixer block, you are only left with one set of stereo outputs. It would be nice if you could send on tone to the 1/4" outs and the other to the XLR and have them be completely independent of each other. As of now, you can't do that. I don't if it's something that could be changed or not. I suspect it is probably a hardwired limitation, though.
            Jan 25, 2007
            Feb 17, 2012 12:32 PM (in response to Ax3M4n)
            They are two stereo paths, or to be more accurate, two potentially stereo. It's just that the majority effects aren't stereo (true stereo or even mono in, stereo out). The amp blocks are mono, so if there's a stereo input before them it comes out as summed dual mono.
            The pan controls in the mixer should actually be labeled balance, not pan. With a balance control you have to think of it as two volume controls. If you hard pan, you're really reducing the volume of the other channel to zero.
            EDIT: I think the one thing I should clarify is that the Input A and B aren't stereo. They are mono inputs, but if you put a mono effect in the path before one that has a stereo output, you can in essence turn them into stereo paths. I think that may be why you're disagreeing with me.
            Jan 25, 2007
            Feb 17, 2012 1:00 PM (in response to Ax3M4n)
            Not to belabor the point, but here's something to try.
            Assume Input B is not being used and the Tone B is muted at the mixer.
            Without any effects and just and amp block before the in the signal split you'd have:
            Input A -->Split ---> Amp --> Path A Mixer --> Stereo Out
            Now, if you put a true stereo effect after the amp in this signal chain, you will have a separated stereo signal coming out of the left and right outputs. You'll hear the separation in your headphones. This wouldn't be possible if this were a mono signal.
            Input A -->Split ---> Amp --> Stereo Delay --> Path A Mixer --> Stereo Out
            The thing that makes this confusing, and yes, frustrating, is that it's somewhat of a matter of trial and error to determine what effects are true stereo. Most of the ones that are stereo are mono in/stereo out.
            Also, note in the scenario I have shown above, the "Split" isn't really doing anything. It's just sending input A to the input of the Amp (or whatever effect you'd have first after the split).
            I've attached what I'd make my tone look like if I just wanted a simple mono in to stereo out tone.
                Jan 25, 2007
                Feb 17, 2012 1:42 PM (in response to Ax3M4n)
                Where do you have the mixer pan controls set in your experiments?
                There isn't really a left and right mixer channel. You have A and B outputs for the mixer, and they each have their separate output level and pan controls. If you have the mixer hard panned, then I would expect to get the results you're hearing.
                    Jan 25, 2007
                    Feb 17, 2012 1:55 PM (in response to Ax3M4n)
                    Well, the "bleed" as you call it is simply the stereo spread of the signal.
                    Don't misunderstand me, I'm not saying that A and B are true stereo under every condition, just that they potentially could be. If you repeat you're experiment putting the stereo delay either before or after the mixer - make sure you have a different delay time on each side of the delay - you'll hear stereo separation even while the B path is muted. This simply wouldn't be possible with a true mono signal. You'll hear both sides being processed independently from each other. If you pan hard left or hard right, you'll only hear one of the delay signals.
                    • daferalo Iknowathingortwo 270 posts since
                      Apr 12, 2010
                      Feb 17, 2012 1:58 PM (in response to phil_m)
                      Phil, I am at "work" right now so I can not probe it, but I am pretty sure that if you perform the test you are proposing by placing the stereo delay before the mixer (I understand in the "pre" position") and then mute path B, you won't hear the right channel of the delay.
                      Best Regards,
                      Daf
                        Jan 25, 2007
                        Feb 17, 2012 2:04 PM (in response to daferalo)
                        I have to double-check as well, but I'm thinking the amp block will give you a dual mono output that will feed both sides of the stereo delay. I'm at work, too, but I will try to check when I get home this evening.
                          Apr 12, 2010
                          Feb 17, 2012 2:29 PM (in response to phil_m)
                          Phil, I did not read well what you said before and I got confused for a little while, but what you say here is correct!!!!! Apologies for misunderstanding!!
                          I mean, if you place the stereo delay at "pre" position, it will feed path A with both channels of the delay in the example.
                          Best Regards,
                          Daf
                Apr 12, 2010
                Feb 17, 2012 1:45 PM (in response to Ax3M4n)
                Hi Ax,
                Again, it is the expected behaviour, but it does not mean that path A and B are mono. It is jus the way you are performing the test.
                Please, try to do the same test, but placing the stereo delay in the path A only. And then, tweak the pan and level options in the mixer to different values.
                Best Regards,
                Daf
                    Apr 1, 2009
                    Feb 17, 2012 4:02 PM (in response to Ax3M4n)
                    Ax3M4n wrote:
                    Apart from feeling a bit stupid,....
                    Not at all! It's a very complicated issue, which I had also misunderstood. We all had a healthy, respectful exchange of ideas, observations, and opinions. And in the end we all helped each other get to the bottom of it. That's what this forum is for. I think you should feel a bit proud rather than stupid - you were a big part of the learning exercise, for me at least.
            Apr 12, 2010
            Feb 17, 2012 1:14 PM (in response to Ax3M4n)
            +1 to what Phil_m said above.
            Ax, the results of your test are correct, but they do not mean that Path A and B are mono. Be aware that you placed a mono-type effect (the amp) after a stereo one, so it is expected to get those results.
            I think Meambobbo's charts are very complete, and as Phil_m said, it can be frustrating to mess around it. However, it is very important to know what happens at "each position" in the signal chain in order to get the best. The only difference between the "path A and B" position and "pre" position in the signal chain, is that in the former you can control what is going to happend to each signal path, independently from the other.
            Best Regards,
            Daf
              Dec 13, 2007
              Feb 17, 2012 4:26 PM (in response to daferalo)
              my mixer diagram was wrong - i fixed it.  it's like phil says - you basically have 4 volume controls - channel A left, channel A right controlled by channel A's pan control, and channel B left, channel B right controlled by channel B's pan control
    Nov 7, 2008
    Feb 17, 2012 5:39 PM (in response to Ax3M4n)
    Yeah I found this thread really helpful too, if only for the fact that it really forced me to sit down and figure out exactly what the best way is to use the signal routing on the HD. I found a way better method of constructing single tone patches as a result. So, helpful times all around!!
    Jan 25, 2007
    Feb 18, 2012 7:44 AM (in response to Ax3M4n)
    I was thinking about this thread some more, and I wanted to sum up a few things.
    I think the way to think about the mono/stereo thing is this. There are essentially three types of effect blocks in the HD500 (and Bean and Pro).
    1. Mono in / dual mono out - this is what most things are. Distortions, filters, amp blocks, and some others would fall into this category. And really it's not true to call these true mono in because if you put them after a stereo effect, they will get both sides of the effect as input. It's just that the input is "mono-ized" to quote the advanced guide.
    2. Mono in / stereo out - these are similar to the mono effects in that they "mono-ize" the inputs, but the output it a stereo image. The Ping Pong Delay would be a good example of this, as well as the panning effects. I think all reverbs fall into this category as well. If you put them before the split, the left output will go down path A, and the right will go down path B. If you put them after the split, but before the mixer, you will lose one half of the stereo image if you hard pan.
    3. True Stereo - these effects maintain a true, separated stereo path through the effect. They will not mono-ize the inputs, so if there's something only on the left side coming into the effect, you won't hear anything coming out of the right side. This is why you using these effects first in the signal chain may not always work the way you want. These include the volume pedal, the panning volume, all the wahs, stereo delay, analog chorus, Q filter, and a few others I'm forgetting now. If you put these before one of the other types of blocks I've described here, the stereo separation will not be maintained. If you put them before the split, the left output will go down path A, and the right will go down path B. If you put them after the split, but before the mixer, you will lose one half of the stereo image if you hard pan.
    As I see it, these three groups cover everything. The one sort of odd thing is that none of the effects are "true mono" in the sense that they will only work with one input. All of them will accept a stereo input, it's what they do with it that sets them apart.
    I hope this clarifies the issue a bit. If anyone sees anything wrong here, please feel free to offer a correction.
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
