282 Views 3 Replies Latest reply: Mar 2, 2012 9:48 AM by Line6Don RSS
nicksaalfeld Just Startin' 2 posts since
Feb 21, 2012
Feb 21, 2012 7:40 AM
What recording apps for mobileIn?
Hi there,
I bought MobileIn because of the promise that it would work with many iphone recording apps (I have FiRe, for example).
However, I cannot find anything which works apart from GarageBand.
Do you know of any specific apps in the AppStore other than GarageBand which are compatible with MobileIn?
I have seen the stock answer " It’s compatible with any app that uses CoreAudio for audio input" many many times, but that is not a complete answer - I would like some options, please.
GarageBand is OK, but not designed for simple 2-mic interviews (which is what I want to achieve).
Any answers?
Thank you!
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Feb 27, 2012 7:51 AM (in response to nicksaalfeld)
    Re: What recording apps for mobileIn?
    I don't think your issue is an app issue - it's a hardware issue.
    The Mobile In audio interface has two mutually exclusive inputs: a mono instrument-level input for guitar, and a stereo line-level input for outboad gear. In order to use two microphones you will need an external device to accept the mic inputs and send the blended output signal to one of the Mobile In inputs.
    So, yes - it's probably best to return the Mobile In and get a single hardware interface that meets your needs. The Mobile In was not designed (nor advertised) for two microphones.
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Mar 2, 2012 9:48 AM (in response to nicksaalfeld)
    +1 to silverhead.
    To use two microphones at you will need an external mixer/device to amplify the mics and send the blended output signal to the stereo line on the Mobile In.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
