723 Views 9 Replies Latest reply: Feb 26, 2012 6:30 PM by BigBob369 RSS
BigBob369 Just Startin' 58 posts since
Nov 9, 2007
Feb 22, 2012 5:02 PM
What is a good sounding headphone for a POD?
Since getting a POD HD Desk this week I realized that I don't have any functioning headphones right now, just old ones where only one side works or the ear cushions fell off,  and with so many out there I was wondering if anyone could give some good tips for picking one.  Something that obviously sounds good for guitar, is comfortable, and not a piece of junk that's going to stop working in a year.  I'm willing to go up to about $50-$70, maybe even $100 if need be. Thanks.
  • chaosbringer Just Startin' 85 posts since
    Jan 29, 2008
    Feb 22, 2012 8:42 PM (in response to BigBob369)
    Re: What is a good sounding headphone for a POD?
    http://www.amazon.co.uk/Grado-SR-60-Headphones-Wired/dp/B0006DPMU4/ref=sr_1_2?ie=UTF8&qid=1329972020&sr=8-2
    I use one that is above your budget (ultrasone 750) but the grado is pretty good just for playing
  • still_fiddlin Just Startin' 69 posts since
    Jan 21, 2011
    Feb 24, 2012 5:11 AM (in response to BigBob369)
    As typical, Line 6's "spec" sheet for your POD actually has zero technical information, aside from really useful things, like the weight, size of the box the item comes in, etc.  Actual engineering data, like input/output impedance, voltage, i.e., "specifications" are absent.  (Pardon my annoyance.)
    For previous POD devices, Line 6 has said they only support headphones with impedance greater than 150 ohms.  If the desktop POD HD is the same (and you have to guess, apparently, because they don't tell you), you will have a hard time finding anything meeting that spec in the price range where you are looking.
    However, many HD owners use consumer-grade headphones with mixed success - just be aware that they could be loud if the POD is really looking for a higher impedance load.  The other thing to realize is that with *any* headphone, it's going to sound different from what comes out in a PA or amplified system, and even what may be going out the line-out to get recorded, so you have to learn to hear and compensate.  How different it sounds can depend on a lot of things, but if you start with something good and relatively "flat" frequency response, i.e., no bass boost, etc., you can work with just about anything.
    With my HD400, I used a 20 year old Sony MDR-V6 pair, which just a year ago could be had for as little as $70, but now they have gone up quite a bit (tsunami fallout?).  I would search postings here, and look on Amazon.com for reviews of headphones in your price range.  Any of the major brands that have pro-lines will be fine.  (I also used a pair of "open-air" Sennheisers that sounded fine, until my wife took possession - she likes to be able to hear the phone ring, whereas I'm happy if I don't.)
  • Dshow Just Startin' 38 posts since
    Feb 18, 2007
    Feb 24, 2012 12:06 PM (in response to BigBob369)
    there is already a similar post: http://line6.com/support/thread/80075?tstart=0
    Maybe it helps
      Jan 21, 2011
      Feb 26, 2012 1:02 PM (in response to BigBob369)
      One of those reviews might have been mine.  I'm still very happy with my 250 ohm DT-770s.  I will say that the more I listen to them, the more I can hear that they do have definite bass hump, but it really depends on the music and your listening preference whether that will bother you.  It's not something, IMO, that affects their use as a POD HD monitor.  As far as the impedance, they work fine in any use that I would have plugged in other phones/earbuds, but you may have to turn up the volume a bit.
          Jan 21, 2011
          Feb 26, 2012 4:47 PM (in response to BigBob369)
          Don't have the box handy, but mine say DT 770 PRO on the side.
          I really only notice the bass on "modern" recordings of popular music.  Much of what I listen to doesn't fall into that category.  The 880s are supposed to be different, and if I had money to spend, I'd get a pair of those, too!
          Really, you can get "regular" headphones and use those (except for the "not supported by Line 6" part) - it's a matter of learning to "hear" what your own monitors output vs what the recorded sound will be played back on, and that covers a wide range, unless it's just you listening back on the same headphones.  Not much different than the problem with monitor speakers.
