122 Views 2 Replies Latest reply: Mar 13, 2012 11:07 AM by Line6Don RSS
gfkopf Just Startin' 2 posts since
Aug 28, 2009
Mar 1, 2012 4:40 PM
UX2 bypass
Hi there,
So I have been using my UX2 with Podfarm for a couple of years now and I love it.  It's amazing - what else is there to say?  Just recently, though, I purchased a MacBook Pro and I loaded Logic 9 on to it.  Given that there is a whole host of new plug-ins and amp models to play with in Logic, I was wondering if there was a way to use the UX2 just to route the guitar signal through to Logic with out Podfarm adding anything to the signal.  Basically, what I think I am asking is, "Is there a way to bypass Podfarm using the UX2?"
My goal here is simple:  I just want the guitar input to reach Logic 9 without anything added to it so that I can start with a "clean slate," as it were.  Does this make sense?
  • vldfkila Just Startin' 3 posts since
    Feb 29, 2012
    Mar 3, 2012 9:34 AM (in response to gfkopf)
    Re: UX2 bypass
    Yes, you can. Inside of Logic select your UX2 as the audio device. That's all it takes. Create an audio track. Tthe output from your UX2 comes in clean. POD effects won't be added unless you want to bring it in as a plug-in.
    • Line6Don Line 6 Support 5,274 posts since
      Mar 14, 2011
      Mar 13, 2012 11:07 AM (in response to vldfkila)
      Re: UX2 bypass
      +1 to vldfkila.
      vldfkila's answer above is correct.
      You do not have to use the stand alone POD Farm application in order to use the UX2 with a recording software. Simply follow the instructions that vldfkila provided above.
      If you still have questions or are still experiencing an issue please start a new thread and mark the discussion as a question. To do so you can follow the link below and Ask a Question:
      http://line6.com/support/community/support/
      For more information about using the Online Technical Support System please review our FAQ at the link below:
      http://line6.com/support/docs/DOC-1451
      Thanks!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
