601 Views 5 Replies Latest reply: Mar 5, 2012 10:14 AM by silverhead RSS
xxpizzapony Just Startin' 6 posts since
Jun 12, 2011
Mar 5, 2012 7:58 AM
Pocket POD's "direct mode" question
Hi guys,
when the cabinet tuning on Pocket POD is setted to "direct mode" I must connect the AMP OUT to a "LINE" IN or to an "INST" IN on my external audio interface?
In both cases, the gain pots of the channel must be pointed at "0"?
Pocket POD in "direct mode" works as a Pre Amp? or I need to switch to "instrument" (or use DI) for a correct connection?
I use a soundcard like this and a simple jack-jack instrument cable.
Thanks.
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Mar 5, 2012 8:33 AM (in response to xxpizzapony)
    Re: Pocket POD's "direct mode" question
    I connect my Pocket Pod headphones output (stereo) to a stereo Line In jack/pair on my audio interface/mixer. Adjust volume levels as desired, using either the Pocket Pod or the audio interface/mixer.
        Apr 1, 2009
        Mar 5, 2012 9:25 AM (in response to xxpizzapony)
        xxpizzapony wrote:
        Your method is the same I've used until the past month, but the signal in this way is recorded stereo and, if I'm not falling in error, it don't seems the better way to proceed...
        Why not? If you want to make use of the stereo FX then you can. If you want a full mono signal just use a stereo-mono adapter and you can still have the Line Level signal coming from the headphones jack.
        The Pocket Pod manual states that the AMP OUT is an instrument level signal. I've never used it with anything other than an amplifier so I can't comment on your question re: using it with a DAW.
            Apr 1, 2009
            Mar 5, 2012 10:14 AM (in response to xxpizzapony)
            A true stereo-to-mono adapter will retain both sides of the stereo signal and merge them into a mono signal. It does not simply take one side. That's different from using a straight-mono plug into the stereo jack. The latter will, indeed, take only one side of the signal.
            Regarding Line Level vs. Instrument Level: As far as I understand, the AMP OUT is always instrument level, even in Direct Mode. I believe (but am not sure) that the Headphones Out is appropriate for Line Level input. All I know is that I have not had any problem with levels feeding the Headphones Out into my mixer.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
