795 Views 1 Reply Latest reply: Mar 19, 2012 11:13 AM by Line6Don RSS
david462 Just Startin' 1 posts since
Aug 31, 2010
Mar 14, 2012 12:05 PM
gearbox tone port ux2 with windows 7 64 bit
Hello
I had a device- gearbox tone port ux2 and operating system windows 7 64 bit.
When I try to install the device i got an error message that says: This software is not compatible with 64 bit versions of window.
What should I do?
There are drivers and if so what drivers to download?
Delete the installer and install again after the installation of drivers?
If someone can explain me step by step how to solve this disturbing problem I'd really appreciate it.
thank you all
David
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Mar 19, 2012 11:13 AM (in response to david462)
    Re: gearbox tone port ux2 with windows 7 64 bit
    It sounds like you might be installing an older version of the software from a disc, in which case the software is outdated.
    Our current version of GearBox 3.72 is compatible with Windows 7 64 bit and can be downloaded from the link below:
    http://line6.com/software/readeula.html?rid=3121
    The latest Line 6 drivers for your operating system are available from the link below:
    Windows Drivers 4.2.5.1:
    http://line6.com/software/readeula.html?rid=4399
    Once the drivers are installed you will need to install the Line 6 Monkey application from the links below:
    Windows Line 6 Monkey 1.51:
    http://line6.com/getrelease?rid=4618
    Once Line 6 Monkey is installed, remove any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available until you are able to launch Line 6 Monkey and detect the device.
    After Launching Line 6 Monkey apply any updates that are available until you have a green check next to each component.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
