818 Views 7 Replies Latest reply: Mar 23, 2012 12:56 AM by jimsreynolds RSS
vorphallack Just Startin' 42 posts since
Nov 18, 2008
Mar 16, 2012 5:45 AM
ENGL E-530 pre amp Connection to POD HD 500
Hi everyone !!! i have a question for you guys....i recentely purchased a ENGL E-530 Rack pre amp and i wonder how can i plug that in to the POD HD 500 if anyone has the same pre amp with te POD or knows how to make this work...let me know...thank you !!!
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Mar 16, 2012 6:17 AM (in response to vorphallack)
    Re: ENGL E-530 pre amp Connection to POD HD 500
    Looking at the manual here ...  http://www.englamps.de/uploads/tx_ddfproducts/OM_E530_Tube_Preamp.pdf
    Cute pre-amp!   There are several ways you could hook up the HD500.  I am assuming you want to go stereo as per the preamp capabilities and that you are more interested in using your pre-amp channels than modelled amps.
    Front of Amp
         Guitar ==> HD Input
         HD 1/4" Output ==> Amp Input
    This is the simplest way and works well for many people.  It works well if you are mainly using the clean channel on your amp or you are only using effects that normally sit in front of the amp(e.g. compression, wah, distortions, some modulations).  Not always so great for reverbs and delays etc, particularly where higher gain tones are used. It is also OK for amp modelling if setup correctly.
    In the Loop
         Guitar ==> Amp Input
         Amp FX Loop Send ==>  HD Input
         HD 1/4" Output Left ==> Amp FX Return Left
         HD 1/4" Output Right ==> Amp FX Return Right
    This way works very well for effects like echoes and delays, reverbs and some modulations.  Not so well for distortions and wah.  Amp Modelling will almost certainly sound weird.
    Four Cable Method (well actually more cause of the stereo)
    Deep breath ...
         Guitar ==>HD Input
         HD FX Send ==> Amp Input
         Amp FX Send Left ==> HD FX Return Left
         Amp FX Send Right ==> HD FX Return Right
    This is the all singing, all dancing method for hookup.  It allows you to put all effects where you want them, to use your pre-amp channels correctly and allows for amp modelling too.  It is a pain to intially get your head around and setup but the results can be excellent.  For more details on 4CM and what it does check the link here.  http://line6.com/support/docs/DOC-2523
    Jan 27, 2010
    Mar 16, 2012 2:34 PM (in response to vorphallack)
    +1 to jimsreynolds,
    Great info! dont forget to check out Meambobbo's guide:
    http://foobazaar.com/podhd/toneGuide/index.html
    And our HD500 connections vid:
    http://line6.com/support/docs/DOC-2492
    Thanks,
    David
        Jun 27, 43450
        Mar 23, 2012 12:56 AM (in response to vorphallack)
        The four cable method that I describe above works partially for this.  It allows you to turn off the POD modelling and use the Engl as your pre-amp model.
        However, what you cannot do is use the Engl Pre-amp into a modelled power amp on the HD.  There is no way to split the two functions on the POD:  Pre and Power amp.  If you want to use your Engl straight into a desk then you would need to use the 'Frequency Compensated' outputs on the Engl as this will apply some of the tonality associated with a power amp (if I understand correctly).
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
