529 Views 4 Replies Latest reply: Nov 26, 2012 1:37 PM by jlej666 RSS
TimUX1 Just Startin' 2 posts since
Jul 15, 2009
Mar 17, 2012 9:44 AM
UX1 Not recognised (OsX Lion)
Hello.
I own a UX1 and I can't get it to be recognised by my macbook.
It started (along with an error message from garage band telling me that there was a midi driver conflict, if I'm not mistaking) right after I tried to instal what I thaught to be à LE standalone version of protools.
I looked up forums to see if anyone had the same problem and, well, apparently that guy did :
http://line6.com/support/message/306228
So I did every thing that was adviced here but it didn't work.
What should I do?
BTW, the cable seems to be fine with my printer.
Thanks.
Tim.
    • Line6Don Line 6 Support 5,274 posts since
      Mar 14, 2011
      Mar 22, 2012 4:19 PM (in response to TimUX1)
      Re: UX1 Not recognised (OsX Lion)
      I would suggest to follow these intstructions instead to completely remove the drivers from the MAC comptuer:
      http://line6.com/support/docs/DOC-2617
      After complately removing the drivers from the computer open the disc utility program located within your utilities folder, select your primary hard drive, and repair disc permissions. Restart the computer.
      After restarting your computer download and install the latest Line 6 drivers for your operating system:
      MAC Drivers : 7.1.3
      http://line6.com/software/readeula.html?rid=4321
      Once the drivers are installed you will need to install the Line 6 Monkey application from the links below:
      MAC Line 6 Monkey 1.51:
      http://line6.com/getrelease?rid=4619
      Once Line 6 Monkey is installed, remove any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available until you are able to launch Line 6 Monkey and detect the device.
      After Launching Line 6 Monkey apply any updates that are available until you have a green check next to each component.
      Next close all open applications and use the License Manager software to de-authorize and re-authorize your device. Make sure to remove the information when prompted to, and then install again when prompted to, this will ensure that you reinstall all of your available Line 6 assets from your account into your device.
  • jlej666 Just Startin' 2 posts since
    Mar 22, 2010
    Nov 26, 2012 1:37 PM (in response to TimUX1)
    I've tried everything over and over and the line 6 monkey still will not recognize the device. Can someone give me a hand?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
