299 Views 2 Replies Latest reply: Apr 7, 2012 8:08 AM by AstroNutter RSS
FrankAbbott Just Startin' 2 posts since
Mar 25, 2012
Mar 28, 2012 8:08 PM
Spider Jam - unwanted noise
I have just purchased a Spider Jam. When moving between the Amp Models I've found that many of them cause a very noticeable static noise to come from the speaker. The noise disappears if I move the Chann Volume slightly up or down. It only happens if a guitar lead is connected and it makes no difference whether or not a guitar is connected at the other end of the lead. Changing leads makes no difference. I've tried a factory reset but again no difference. I am using the Fbv Express pedal but this makes no difference either. I really don't want to return the amp but I can't live with the problem.
Any advice gratefully received.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Apr 6, 2012 3:33 PM (in response to FrankAbbott)
    Re: Spider Jam - unwanted noise
    This is most likely an internal wiring/component issue. The only tangible troubleshooting I can offer is to try re-installing the Firmware of the amp, but there are quite a few steps involved (one being that you need an SD Card under 2GB). Here are the instructions to do this, if you wish to pursue it: http://line6.com/support/docs/DOC-4778
    If you do end up trying this and the symptoms persist, the root cause of what you're experiencing is deeper (at the hardware/component level). This would necessitate a repair tech's involvement to open up the unit and troubleshoot/fix the problem. I can get you in touch with the Line 6 UK Service Team, if it comes to that. Please let me know.
  • AstroNutter Just Startin' 5 posts since
    Jul 2, 2008
    Apr 7, 2012 8:08 AM (in response to FrankAbbott)
    I think if U use a noise gate, U can eliminate buzz & static. It will always come back when your playing but that's what gives you the  "real deal". Right? Think Jimi' or Link'! U gotta have that in there but only when U want it there, right?
    PS: Jim Marshall - Requiescat In Pace.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
