252 Views 7 Replies Latest reply: Apr 4, 2012 1:04 AM by hulbert RSS
WaKe21 Just Startin' 4 posts since
Mar 27, 2012
Apr 2, 2012 3:22 PM
Line 6 ux2 microfon  error help
hi
Gives
the following error that I could not figure out a new ux2 waiting for your help .s.s.s.s.s
I tried all of the active mixer devices were found, but did not issue driver
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
    Apr 3, 2012 1:09 AM (in response to WaKe21)
    Re: Line 6 ux2 microfon  error help
    Hello Wake21,
    I am not quite sure what you are saying. I am sorry. Could you tell me some more about what is not working? Thankyou. I'll google translate in Turkish too:
    Bana ne çalışmıyor hakkında biraz daha bahseder misiniz? Teşekkür ederim. Google da Türkçe olarak tercüme edeceğiz:
    I checked my own Digital Audio Interface Properties (comparing Turkish and English) and mine is exactly the same as yours.
    Kendi Dijital Ses Arabirimi Özellikleri (Türkçe ve İngilizce karşılaştırarak) kontrol ve mayın tam sizin aynıdır.
    I hope I can help.
    David
    Ben yardımcı olur umarım.
        May 12, 2011
        Apr 3, 2012 7:49 AM (in response to WaKe21)
        Hi Wake21,
            When you run Pod Farm standalone, is the "mic1" and "mic2" option there in "input" in "mixer view"?
        If you select mic 1 and plug your microphone in to 1/L on the ux2 and press in the phantom power button next to the mic sockets, does anything happen in Pod Farm mixer view? Is there any movement on the meters?
        I am not exactly sure what the problem is that you are having. Are you getting an error message when you try to use Pod Farm?
        I hope I did not offend you by writing Turkish as well. I was not sure if you would prefer Turkish as your picture seemed to show Turkish writing.
        David
            May 12, 2011
            Apr 3, 2012 10:40 AM (in response to WaKe21)
            Hello Wake21,     I have a condenser microphone that I use, but every time I use it it has a rumbling noise. I am not sure if it is damaged or not, but I do know that condenser microphones are very susceptible to water droplets from the air. Sometimes I have fixed it by putting the mic above a heater for a long time (in a plastic bag), but I still have problems. Sometimes the noise can be very loud and other times less loud.  Could this be the problem with your microphone?
            Kullandığım bir kondansatör mikrofon var, ama kullanmak her zaman bir guruldama gürültü var. Ben hasarlı veya değilse emin değilim, ama kondenser mikrofonlar havadaki su damlacıkları çok duyarlı olduğunu biliyoruz. Bazen uzun bir süre (bir plastik torba içinde) için bir ısıtıcı üzerinde mikrofon koyarak sabit, ama hala sorunlar var. Bazen gürültü çok yüksek sesle ve diğer kat daha az gürültülü olabilir.  Bu mikrofon ile sorun olabilir mi?
            David
                May 12, 2011
                Apr 4, 2012 1:04 AM (in response to WaKe21)
                Hello again Wake21,
                   I am sorry. Unfortunately I do not understand what you are saying.
                I will write some questions:
                Do you hear anything through the ux2?
                Does Pod Farm start?
                Are you using a recording programme?
                Are you using Pod Farm Standalone or the plugin?
                   Üzgünüm. Ne yazık ki ne diyorsun anlamıyorum. Ben bazı sorular yazacağız:  Eğer ux2 üzerinde herhangi bir şey duyuyor musunuz? Pod Farm başlatmak mı? Eğer bir kayıt programı kullanıyor musunuz? Eğer Pod Farm Bağımsız veya eklenti kullanıyor musunuz?  I hope things work out well for you. Hopefully we can understand each other more.
                God Bless,
                David
