260 Views 1 Reply Latest reply: May 22, 2012 12:43 PM by Kneehow RSS
Bergair Just Startin' 3 posts since
Nov 30, 2011
Apr 4, 2012 1:18 PM
JM4 Looper with POD X3 Live
I'm using a Line 6 Spider II HD with cab 4x12 "old" Amp, with the old FBV Footcontroller.
Now i've got a JM4.
Can i connect  FBV  AMP and JM4 somehow?
i got a POD X3 Live just for testing. Is it a good renewal instead of the old FBV?
insights with the POD X3 Live:
The best way to use is i think with the FX send and return stereo from POD / Stereo Line out from JM4.
What about the 2nd Pedal Jack from the POD? Doesn't work with JM4 :-(
What is the best setting on my AMP Channel to get clear sound, because i wanna use just the effects from POD or JM4.
Clean Green or Clean Red and what for setting with Drive bass middle treble?
Thanx for help
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    May 22, 2012 12:43 PM (in response to Bergair)
    Re: JM4 Looper with POD X3 Live
    Spider II HD settings: Clean Green. Drive maybe around 9:00, Bass-Mid-Treb at 12:00, Channel Vol at max.
    Guitar into POD X3 Live into JM4 into Spider II HD. The Spider II HD you won't need to switch channels... just leave it set as a "clean" amp tone. The X3 Live does all the tone/effects changes and the JM4 allows you to make loops of what you're playing through the X3 Live from your guitar.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
