195 Views 0 Replies Latest reply: Apr 14, 2012 12:40 PM by howarddavidp RSS
howarddavidp Just Startin' 18 posts since
Apr 12, 2012
EVH "Brown" sound, my settings
Hello,
I have a Spider2 and 4x12 cabinet, and once I got through with looking at others serttings, and threw out what I used on other amps, I think I found my idea of the famous sound (with good humbucker):
Amp Model:
Green Insane
Drive:
3 o'clock
Bass:
2 o'clock
Mid:
4 o'clock
Treble:
1 o'clock
Channel Volume:
MAX, 5 o'clock
Effects:
None
Delay:
8:30 o'clock
Reverb:
10 o'clock
I have the STOMP/PRE-AMP turned on as well as the NOISEGATE.
For a single coil guitar, I would increase the drive, turn bass up to 3 o'clock, maybe 4 depending on your pickup.  IF it is a little too strong for you, back down the Channel Volume a click or 2.
Good luck with those, I didn't like the CRUNCH model, either red or green, never got it to feel right for the EVH sound.
My biggest issues was I first tried to use settings that worked on other amps.  Once I got fed up with the settings not sounding like they did before, I  started from scratch and found what I wanted.  I have learned that for Line 6, don't apply what might be the right settings on other amps, play with the settings from scratch until you find the sound you want.
David
