125 Views 4 Replies Latest reply: Apr 15, 2012 2:18 AM by Ivarsson RSS
Ivarsson Just Startin' 16 posts since
Jun 3, 2011
Apr 15, 2012 1:27 AM
POD HD PRO - digital clocking problem
I have some problems regarding digital output for the pod hd pro. I have the pod connected to a Profire 2626 interface using spdif and usb running directly to the daw. I´ve managed to get everything working with analog outputs but I would really like to go digital now. My goal is to record the dry signal digitally on the daw and then use the spdif to re-amp the signal later.
How do I change the pod to clock from an external device instead of using internal clocking? According to the manual it is best if the pod handles the clocking internally but from this I assume that I can change the clocking-mode on the pod too. Does it depend on the order in which the devices are turned on or something like that? I´ve not been able to find this information in the manual.
Regards
/ Mattias
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
