Apr 18, 2012 11:44 PM
Pod HD PRO and VOLUME PEDAL
Like (0)
Hi!
I am using HD PRO with a Nobel midi footcontroller and an external expression pedal. Everything works properly, but I have a question for everybody: I am not able to set a "wake-up" volume value for presets. Let me explain: I can set minum and maximum value for a volume pedal box, relating it to my expression pedal position. When I recall the preset, however, it starts with volume pedal set on maximum. I think that this is s problem in live situoation because everytime that I choose a preset on stage, I must move my expression pedal to obtain my desired volume. In the past I used several other preamp-effect unit (the last one: Voodu Valve) and there where 3 different settings for volume pedal: minum, maximum and starting position.
Probably I'm following a wrong way to solve this little problem. Anyone can help?
thanks everybody!
Michele
Hi, I just receivrd an answer from technical support: no chance to store a "wake-up" value for volume pedal; a preset starts always with volume on 100%.
I hope that Line6 can introduce an improvement with future update
