313 Views 3 Replies Latest reply: May 1, 2012 9:15 AM by optimus_7 RSS
optimus_7 Just Startin' 18 posts since
Apr 15, 2007
Apr 30, 2012 7:04 PM
Anyone else finding this problem with HD500?
Hey Line6-ers.  I've been gigging with my HD500 for a year now and I have had great success with it. That is - until I attempt to use the 4CM with my amp (a Blackstar HT Stage 60).  I've been using my amp as a POWER amp only at shows - all tones are assembled in the HD500.  When I come home and my rig is all dissassembled, I play a lot through my amp without any effects - and I LOVE the sounds coming out of it.  So I try using the 4CM to create new sonic fun - and alas, it sucks the tone right out of the amp.  I tried the solution found here, http://line6.com/support/docs/DOC-2522 and still had no luck, though it was marginally better.
I decided to do some tests for myself to nail down the problem.  I've abandoned the 4CM for now opting to use the HD500 as a pedalboard that all goes into the preamp, since I'm only using effects that are appropriate before preamp.  Even still, I found that simply connecting the HD500 DESTROYS the tone/dynamics/etc. of my amp. The doc aboe alludes to this, but the solution of adding an EQ and rasing the gain 6 dB, then lowering the gain on the mixer by 1.5 dB just bugs me, and honestly, it didn't help much. Using a test tone from a cable tester to measure levels, I found that there is a 2.8 dB (not 6 dB) difference between the HD500 Input and the FX send. (on STOMP setting)  Why? I don't know.  By the way, I saw somewhere that adding effects to the chain (all effects are turned off) will suck your tone out - there is NO difference between how many effects are in the chain - it does not reduce the gain stage by adding bypassed effects - I've checked this thouroughly now.
But the problem of gain loss between Input and FX send was easily solved: Put the FX loop after the Mixer and raise channel A and B each by 3 dB, and pan both A and B to center. This will still work for 4CM users. "SICK!! my tone is back!  This is going to be awesome!" I say to myself.  Then I start scrolling through patches to make the necessary changes to the FX loop and Mixer, and notice - uh oh! 2 of my patches, WITH ALL EFFECTS ON BYPASS, and all other settings identical, sound TOTALLY DIFFERENT!  WTF?
I went further diagnostic diving and found that If I have a chorus, or a fuzz face, (don't know if there are others) in position 1 of the effects chain (bypassed, again) it completely changes the tone.  If they are anywhere else in the chain, or other FX are in position 1 - no problems.  Just wondered if others are seeing this.  Is it a bug in the new firmware, or has it been a bug all along?  EDIT - When I say position 1 - I don't mean Block 1 - I mean the first thing in the chain of effects.
Cheers,
-Tyler
  • meambobbo Iknowathingortwo 1,702 posts since
    Dec 13, 2007
    May 1, 2012 7:14 AM (in response to optimus_7)
    Re: Anyone else finding this problem with HD500?
    Not sure about the gain level issues, but it sounds like the issue with the FX in the beginning of the chain has to do with input impedance.  See the advanced manual pages 2.5 - 2.7.  http://line6.com/data/6/0a06434dfb244f7b7f489af64/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.0%20-%20English%20%28%20Rev%20A%20%29.pdf
    If you are using "auto" impedance, the Pod is switching the impedance to the closest impedance matching the actual impedance of the modeled effect that the input signal is first routed to.  Amps and most effects are 1M.  The 2 you referenced are 22k.  That's a huge difference.  The tone will be much darker and looser feeling with those effects first in the chain.
    You can override this by going into the system menu and changing the impedance setting to 1M (or your preferred setting) instead of auto.  Or just don't place those effects first.  And this can be made a global setting or per patch.
      Dec 13, 2007
      May 1, 2012 7:20 AM (in response to meambobbo)
      Your issue with the 4 cable method might be the same issue.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
