May 11, 2012 3:52 AM
FX return instead of power amp in?
Like (0)
I'm looking at a couple of Ampeg bass amps, Micro VR and Micro CL. I would like to use the HD500 and bypass the preamp, but there's line in or power amp in. They do both have FX send and return, so I thought I could connect the HD500 to the FX return. Will that work well? I assume it would be guitar level raather than line level?
Thanks!
Yes that will work....and you can choose for "line" level or "amp" level.
+1 Holeshot. Start off with your output switch set to 'Amp' and if things are significantly quieter than with the 'real' amp then move up to 'Line'.
Thanks guys!
