243 Views 1 Reply Latest reply: Jun 13, 2012 11:41 AM by Line6Hugo RSS
haarvester Just Startin' 1 posts since
May 19, 2011
May 16, 2012 2:42 AM
Problem with looper in Pod HD300
Hi, during recording with looper (in post mode) everything sound perfect but when looper replayed it sound like mono. In pre mode track sound the same like I played but of cource can't change preset to record next part without changing background.
Samples:
http://speedy.sh/KHFpw/looper-problem.mp3
First part in post mode (lights on) and second replayed by looper.
What is wrong?
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    Jun 13, 2012 11:41 AM (in response to haarvester)
    Re: Problem with looper in Pod HD300
    Hello,
    This looks to have been resolved through your support ticket:
    You need to make sure that the unit is in Pre mode (i.e. the PRE/POST light is off) the entire time you are playing with the looper and the signal will be sent through the stereo delay
    If the PRE/POST light is lit the signal will sum to mono.
    You need to make sure that the unit is in pre (i.e. the PRE/POST light is off) the entire time you are playing and the signal will be sent through the stereo delay
    For future technical support problems or inquiries, please use the following link to contact support directly with your inquiry:
    http://line6.com/support/tickets/
    Regards,
    Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
