Jun 4, 2012 1:33 PM
HD 500 4 Cable Method with Mesa Dual Recifier
Like (0)
Hi all. Just got me a brand spaking new Dual Rectifier. Before I go out and buy pedals to sprinkle it with, I want to try to once use the HD 500 for FX only.
Sorry if old, but this guys post and PDF are great.
http://jvmforum.com/phpBB3/viewtopic.php?f=9&t=5333&sid=05c3a3b59eaf9f9f760fb689567d7529
Granted I do not have a JVM but I am assuming the principles are the same.
So here is my first road block. I connected the HD500 using the 4 Cable Method and I got some tone but only on channel 1? When I hit channel 2 or 3 it goes mute.
Anyone else out there with Dual Recto's using the HD 500 with the 4 cable method?
Thanks!
Anybody use the 4 cable method with an amp close to it? I really wanna try the 4C method, just dunno why it makes the 2 channels go out.
Did you set the ASSIGN switch in back of the unit to LOOP ON, and then select correct levels using the SEND and MIX knobs?
I don't own a rectifier but that's what the manual suggests:
Hi, thanks for the reply. Yes I had the FX loop engaged. Raised and lowered the FX level loop and still channel 2 and 3 have no sound
There should be another knob on the back labeled ch1 ch2 ch3 and ft switch make sure its on ft switch.
