288 Views 3 Replies Latest reply: Jun 12, 2012 1:13 AM by skmachette RSS
skmachette Just Startin' 4 posts since
Nov 14, 2006
Jun 8, 2012 11:36 PM
Best pedal to control wah/volume on pod pro HD
I'm having no luck controlling either wah or volume via an expression pedal over midi. I've checked the forum and am a little confused if this is possible. Would it be better and easier to get the line 6 EXP-1 ? My only concern is there isn't a expression jack input in the back of the HD pro so I'd have to go via my keyboard (axiom 61) which is essentially what I'm trying to do presently.
Would appreciate any advice and or guidance.
Thanks
S
  • samuelito2011 Just Startin' 105 posts since
    Nov 14, 2011
    Jun 9, 2012 8:16 PM (in response to skmachette)
    Re: Best pedal to control wah/volume on pod pro HD
    Hello there!
    Actually im using the line 6 EXP-1 with my gear and it works almost properly, wherever i assign to it works really well like wah/vol, etc... however, the main issue that everyone face is when you are editing with hd edit, the software itself make it confuse and change the parameters without you knowing, the thing i do when im editing a patch is to disconnect the cable and connect back the expression pedal and everything come back to normal...
    I hope it helps you
    im sorry if im not really clear to you but english is not my main language!!!
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Jun 10, 2012 7:17 AM (in response to skmachette)
    It is possible to control the wah and volume on the HD Pro via MIDI, but you don't do it by controlling those things directly. You have to set those effects up to controlled by the expression pedal controllers EXP-1 or EXP-2. Then once you do that, you can control EXP-1 and EXP-2 via MIDI. The MIDI functionality of the HD Pro is described in the Advanced Guide.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
