198 Views 12 Replies Latest reply: Nov 16, 2012 4:32 AM by pikeral RSS
wolfgang76 Just Startin' 29 posts since
Nov 13, 2011
Jun 21, 2012 7:15 PM
SV 212 mkII closed back mod
I am considering modifying my SV 212 from opened back to close back, I was going take the back off and and cut a piece of wood that seals most of the back.
Has anyone tried this before? Do you think its a good idea?
My concern is that the tubes will be sealed inside with no air vents, is this a bad thing?
Or should I cut a small hole/vent where the tubes are? In saying that would that defeat the purpose of  going for a closed back effect in the first place?
  • jandirk Just Startin' 27 posts since
    Feb 18, 2008
    Jun 22, 2012 12:43 AM (in response to wolfgang76)
    Re: SV 212 mkII closed back mod
    I'd probably think twice, sound-wise. My guess is that they made it an open back amp for a reason. I've played through a hd100 with a closed cabinet (no V30s though) and it sounded not good. On the other hand, the Line6 cabinet suited for the HD100 is closed.
    I'm not that experienced, but my guess is that you'll need a ventilator of some sort, which will probably undo any effects induced by the closed back. Bear in mind that the tubes are more or less in the middle of the back.
    If you really want a closed back, I'd say sell your 212, and buy a hd100 with a closed 2x12 cabinet.
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Jun 23, 2012 1:27 PM (in response to wolfgang76)
    Why not do the roadking thing...just add a 212 sealed cabinet...get some thump and some openback...
        Feb 18, 2008
        Jun 25, 2012 9:45 AM (in response to wolfgang76)
        I assume the closed cabinet had V30's in it? Anyway, be shure to change only 1 parameter at a time to compare your sound.
        Jan 24, 2007
        Jun 25, 2012 1:41 PM (in response to wolfgang76)
        that is exactly what I did...I loathe V30s...I use SV112s...I have a MK1 and a MK2....I run a 212 in tandem...All 16 ohm in parallel....5.3 ohm load....I use Madison Minstrels which are rated @ 165 watt...V30s do tend to work better in a sealed cab...The air pressure keeps them from breaking up too early...
        I think if you put some high rated drivers in the SV that should help you get around the breakup...EV12L, Commonwealth...or some such that is rated upwards or 200 watts...
  • cgtrox Expert Line 6 User 1,638 posts since
    Jan 25, 2007
    Nov 7, 2012 8:58 AM (in response to wolfgang76)
    I put an Eminence Red, White and Blues in mine and I run it with a marshall 2x12 cab with 75's in it. The Eminence is 120W and sounds very clear, coupled with the scooped deep thump from the marshall it's a match made in Heaven!
    cgtrox
  • pikeral Just Startin' 126 posts since
    Feb 5, 2009
    Nov 16, 2012 4:32 AM (in response to wolfgang76)
    I use a closed back 212 with my SV212, V30's in the closed back and WGS HP Reapers in the open combo and it sounds amazing. Sounds great in an X pattern as well. I A/B'd my SV with my friends triple rectifier and the SV sounds smoother.
