125 Views 4 Replies Latest reply: Jun 29, 2012 10:30 AM by jay182 RSS
jay182 Just Startin' 4 posts since
Feb 16, 2012
Jun 27, 2012 7:45 AM
HD500 volume problem on other patches
I bought my HD500 last June 10, 2012 and I started making my own patches for live use (I used USER 1 to save my patches). I plugged my HD 500 in the power amp of my amp and I used the line switch and I also used combo amp settings. I was able to successfully make my 1st 4 patches in User 1, bank 1 (A, B, C, D). My problem is when I tried making my other patches on the next banks, there was a dramatic loss of volume even if I will make the same settings similar to bank 1. My solution is to copy the patch/patches that I made on bank 1 user1 on the next bank and just edit them to maintain the proper volume. But my question is: is this normal?! Or is this a firmware problem. By the way I'm using ver 1.3, I didn't update my firmware to version 2.0 because. Thanks!
    • jimsreynolds Power User 2,227 posts since
      Jun 27, 43450
      Jun 27, 2012 12:16 PM (in response to jay182)
      Re: HD500 volume problem on other patches
      Couple of things it could be.   The easiest way for us to check is if you could post up
      -  a good patch
      -  a problem patch based on that good patch.
      If you want to do this you will need to
      1. Save the patches using HD Edit
      2. rename each patch file as FileName.jpg - this site does not allow you to upload files with the default HD Edit file extension - e.g. 'clean.jpg'
      3. Reply to this post and use the 'Advanced Editor'  A file upload box will appear at the bottom of the editing window
      Some ideas though:
      • Are you using the full version of the amplifier or the 'pre' version on your problem patch?
      • Are the input settings on your old patch the same as your new patch (e.g. Input 1 = Guitar, Input 2 = same) ?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
