675 Views 11 Replies Latest reply: Feb 17, 2013 10:59 PM by geppert RSS
rumpelstiltskin Just Startin' 8 posts since
Aug 20, 2007
Jun 30, 2012 10:43 AM
MK1 Spider valve 212 volume problem
Hi all,finally got round to getting a spider valve,bought it second hand.When i went to buy it he turned it on,both volumes i noticed were down but there was an extremely loud feedback,which i thought was weird,especially with no volume on amp?When going through the presets its fine,but if you just switch the amp  on ,have the  volumes turned down etc,then turn/go through the blues/clean/insane knob on the left, the volume is instantly loud as hell!,until you just turn the volume knob(not master) up a bit from it's zero position,then sound goes back to zero and turning the volume knob works as it should??Hope i've described this ok?:-)Thanks in advance for any help,cheers.
  • jandirk Just Startin' 27 posts since
    Feb 18, 2008
    Jun 30, 2012 12:53 PM (in response to rumpelstiltskin)
    Re: MK1 Spider valve 212 volume problem
    First, the settings on your amp selector (clean, twang, etc) includes the channel volume. So, if you change your setting from one amp to another, you'll get the pre-programmed channel volume with that. And the're pretty high, especially on the hig gain channels.
    Second, you may be having a faulty master volume. Try selecting an amp, then turn the channel volume low (say 8 o clock). Now slowly turn your master volume up and see what happens. Is it making noise, is your sound going on and off? In both cases you'll want to have your master potmeter replaced.
      • made4praise Just Startin' 9 posts since
        Oct 18, 2010
        Jul 8, 2012 4:42 PM (in response to rumpelstiltskin)
        I found when I want to switch amp style settings, to push the manual button and stay in manual mode to switch all of the settings and the volume does not jump. If you are in a bank it will maintain all of the settings of that bank, and will keep the bank after you have made the changes. The secret is to go into manual mode when switching amp types, and then back to your A,B,C, or D setting after you have made the changes. It works for me.
          Feb 18, 2008
          Jul 9, 2012 10:31 AM (in response to made4praise)
          The MK1 doesn't have a manual button.
          The behavior of your channel volume knob still sounds normal to me. The knob may be on zero, when you switch to another amp the channel volume will be set to the pre-programmed value. Depending on the amp type and the setting of your Master volume, this can be loud as hell. Take insane, with your master on 8 o'clock and a guitar in front youre likely to get feedback.
          Not to say that there's nothing wrong with your amp - just trying to exactly establish what may be the issue here.
  • robertshimer Just Startin' 1 posts since
    Jul 21, 2012
    Jul 21, 2012 10:44 AM (in response to rumpelstiltskin)
    I have a spidervalve 212 that's doing the same thing.
      • Stoofercat Just Startin' 1 posts since
        Feb 12, 2013
        Feb 14, 2013 5:35 AM (in response to rumpelstiltskin)
        Hi fellow guitar players and amp slaves
        I bought one of these  amps and i'm having the same problem! I can't turn my master / channel volume past 0.5 never mind 11!
        Firstly they are great amps I also have a spider jam which I love (I dont work for line 6). I've done a lot of reading on this problem and here's what I found:
        They amps are loud - although that dosen't forgive them being able to be turned down and controlled. Unfortunately you are stuck with it has there is no update / software soution for the mark 1's
        The problem is caused by the presets in the software being set too loud - doesn't matter what you have selected on the master volume and channel volume they get overridden by the software preset. I've talked to line 6 and they have informed me that you cannot adjust the preset volume on the mark 1's :-( You can painstakinly do this on the mark 2's but not the 1's!
        You could also have a pot problem (don't we all:-) try some contact spray from Maplins and clean them up. You can have them replaced if you google the parts. I'd suggest getting a qualified tech to do it - there are some killer voltages in the inside of the case - don't do it yourself! (* you have been warned!)
        Other solutions:
        1. Get used to turning master/channel volume to 0 everytime you dial something in. Bring them up slowly and pray
        2. Factory reset (hold A channel button down and power on - you will loose your presets. Didn't work for me but worth trying
        3. Use a FBV footpedal to control the volume - works ok
        4. Buy an power soak - attenuator - cheap ones for £30 or expensive ones >£250. This is basically a power soak that sits between your amp and speaker. This will allow you to play in your bedroom without 'bending' the walls. If anyone knows a good cheap one let me know
        5. Try changing the channel volume pots with a log pot may help
        6. I've also hear that you can mod the pot's to be less responsive
        After all this i still love the sound. When you get it right the tubes sing! It's worth the hassle for me sat at home. I'd be mighty ****'d if I had to use this amp on stage. I still think Line 6 should come up with a simple fix for the firmware and offer this has a fix for a reduced cost. Until then lets all take out amps to their offices plug them in and feck about with amp selection till they have no windows left!   Come on Line 6 get it sorted and make us happy. Look after your legacy equipment and customers.
        Happy noodling - let me know how you get on
        SC
  • geppert Just Startin' 188 posts since
    Nov 8, 2010
    Feb 17, 2013 10:59 PM (in response to rumpelstiltskin)
    Rumple and others,
    Welcome to the Spider Valve. I have a SV212MKII, SIV120, and a DT25 (this is the bomb).
    I'll mention a few things just as an alternative frame of reference.
    These are difficult amps to "get your head around" at first especially with the insane volume swings between presets etc.
    ALL of the 16 amp model presets on the SV212 (left hand knob named "Clean, Twang, Class A, etc.) are not overwritable in those locations. This means ANYTIME you select a preset from this knob you will get the huge volume swings that you are experiencing. Stoofercat explained it very well. This wrecks total havoc with people trying this amp in the store as you can imagine ???
    The trick is to get the sounds you want saved into the channel preset locations with the relative channel volumes set to your requirements, then, when you select presets from the channel locations, they will be at equal volumes. I NEVER select presets from the left hand model knob because you cannot modify and save into these locations and so it is a bit dangerous to use this method ESPECIALLY if your master volume is up. Always keep this in mind.
    When I first got the 212 I set up and saved a bank of all the 16 amp models (found on that left hand knob) with all the individual channel volumes set to equal them out (also at a lower level so I could turn up the master volume past 1 .... lol !!). Then, I auditioned them easily, found the ones I liked, and went from there.
    MadeforPraise mentioned a great alternate method with the "manual button" but the MKI doesn't have one only the MKII's.
    As a wind up, I would say that IF you have your Master Volume turned up be careful, DO NOT select presets with the left hand model knob because the volume will be deafining. Essentially, you need to "customize" your presets with lower channel volumes stored in the channel locations in order to use the Master Volume at higher levels. Capeesh?
    Hope this helps with the understanding of this amp's architecture a bit?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
